How do Indy's rocker shafts hold up to roller springs? #965903
04/04/11 04:39 PM
04/04/11 04:39 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Just curious if the Indy rocker arm shafts like they provide w/ their 440-1 kit hold up to 600#s OK, or if they're not beefy enough and end up oblonged / egg shaped after usage. These would be for use w/ plain-bearing style rockers, not needle-bearing fulcrums.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965904
04/04/11 05:15 PM
04/04/11 05:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use their thick wall shafts with zero failures.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965905
04/04/11 10:09 PM
04/04/11 10:09 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
shafts seem ok, but this is what there rocker arms do with to much pressure....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: How do Indy's rocker shafts hold up to roller springs? [Re: Old School] #965906
04/04/11 10:45 PM
04/04/11 10:45 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I broke three 1.5 offset rocker on a 640 lift cam last year they were IND black arms i know four guys that have broke rockers and they went to JESEL but i got me a set of T&D shaft mount rockers i got 1.6 rockers on a 725 lift cam i will see if they hold up in a 572 stoker. GOOD LUCK
Re: How do Indy's rocker shafts hold up to roller springs? [Re: Old School] #965907
04/04/11 11:26 PM
04/04/11 11:26 PM
sg66mopar Offline
sg66mopar  Offline
Same situation here. A little more lift and spring pressure but not many passes before we broke rockers.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: sg66mopar] #965908
04/05/11 12:05 AM
04/05/11 12:05 AM
KY
juicedcuda Offline
juicedcuda  Offline
KY
They dont!
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965909
04/05/11 10:54 AM
04/05/11 10:54 AM
BradH Offline OP
BradH  Offline OP
I'm well aware of the issues that the Indy (Dove) rockers have w/ roller-level spring pressures and am only interested in how the shafts themselves hold up. I would never run the Dove rockers w/ that much spring pressure.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: Old School] #965910
04/05/11 11:31 AM
04/05/11 11:31 AM
NC
440Jim Offline
440Jim  Offline
NC
What spring pressures and how much time were on the rockers?
Re: How do Indy's rocker shafts hold up to roller springs? [Re: steeldust] #965911
04/05/11 11:33 AM
04/05/11 11:33 AM
NC
440Jim Offline
440Jim  Offline
NC
What spring pressures and how many passes when you started breaking them?
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965912
04/05/11 11:50 AM
04/05/11 11:50 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Did you give up on the VI's Brad and switch to Indy?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BloFish] #965913
04/05/11 11:54 AM
04/05/11 11:54 AM
BradH Offline OP
BradH  Offline OP
The Stage VIs have a pending deal on them; this is just looking into options for shafts for the Victors since Hughes doesn't sell theirs separately anymore (only as part of rocker arm kits) and my used RAS shafts are going w/ the Stage VIs. Will still be using Hughes/Probe rockers w/ the Victors.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965914
04/05/11 12:27 PM
04/05/11 12:27 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
definately run the thick wall shafts. the kit shafts will bend big time they are junk...I have no problems with My indy 1.5 black rockers
700 + lift and 7800 rpm..Knocking on wood as I type
Re: How do Indy's rocker shafts hold up to roller springs? [Re: BradH] #965915
04/05/11 12:41 PM
04/05/11 12:41 PM
BradH Offline OP
BradH  Offline OP
Also curious to know if Harland Sharp's shafts are the same diameter as stock. They're really beefy, too, although the oil holes (as I recall) are done differently than what most other shafts have. Anyone run HS shafts w/ non-roller bearing rockers?
Re: How do Indy's rocker shafts hold up to roller springs? [Re: 440Jim] #965916
04/05/11 02:12 PM
04/05/11 02:12 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i just changed springs to k motion 950,s. they are about 755 @1.200. they did not last an hour.
Re: How do Indy's rocker shafts hold up to roller springs? [Re: RADAMX] #965917
04/05/11 02:53 PM
04/05/11 02:53 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
We use Mopar perf HD shafts with Comp 948 springs {950@ 1.20 open] and Indy black 1.5's...geometry is dead on with plenty of oil uptop. 440-1 offsets....broke 1 ex rocker in 15 yrs. Lucky?
The little old lady from Pasadena is back!
Re: How do Indy's rocker shafts hold up to roller springs? [Re: Old School] #965918
06/16/11 01:54 PM
06/16/11 01:54 PM
Mo.
racerx Offline
racerx  Offline
Mo.
...I broke a rocker a few weeks ago with the car idling in the garage can't remember the spring presure off hand but the cam is a solid roller with 693/706 with 274/277@50 and it broke a rocker almost like in the shape of a C
Re: How do Indy's rocker shafts hold up to roller springs? [Re: 440Jim] #965919
06/16/11 02:14 PM
06/16/11 02:14 PM
ky
68roadrunner Offline
ky
mine was good for a hundred passes with 300# on the seat and 690# open.
and also one shaft was cracked when i took them off.
did not know they offered a thick wall version, thats what i get for not buying from bg.
