Mopar IRS #965877
04/04/11 04:26 PM
04/04/11 04:26 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
A couple of years ago I posted about Blue Moon Motorsports making an IRS for mopars. That's definitely dead as of January of this year. With Heidt finally fixing their IRS to have an upper control arm, that looks to be a possibility, though one with a little bit of fabrication involved.
Does anyone know of any other routes to an independent rear on a classic mopar? I don't care about drag racing at all, so typical "IRS = bad for drag" concerns are moot.
'67 440 Satellite
Re: Mopar IRS [Re: Explodo] #965878
04/04/11 05:35 PM
04/04/11 05:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Have you looked at Vipers and LXs?
Re: Mopar IRS [Re: RodStRace] #965879
04/04/11 05:54 PM
04/04/11 05:54 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
I'm okay with taking partial bits, like I'd have to do on the new Heidt thing, and then adapting it to work for me, but I distrust my ability to properly build a complete cradle that includes all mounting points for the arms and everything.
My impression was that for the LX or Viper rears I'd have to build everything. Am I incorrect in that? Are they sub-assemblied enough that just an adapter need be fabricated?
Edit: Okay, the LX is a subframe, but I can't find a complete picture of one anywhere. Anyone have a link?
Re: Mopar IRS [Re: Explodo] #965880
04/04/11 06:57 PM
04/04/11 06:57 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There was a kid on here who put the IRS out of an early '90's Thunderbird under a '66 Dart or Valiant. He had lots of pictures, maybe he will chime in.
Re: Mopar IRS [Re: slantzilla] #965881
04/04/11 09:21 PM
04/04/11 09:21 PM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
I think the IRS out of a Lincoln Mark VIII is what you are looking for, I believe they have a cradle system. Also, I thought about using the IRS out of 88-89 Conquest/Starion. This rear might not hold as much power as the 8, but it is Mopar (well, sort of)
Re: Mopar IRS [Re: roadrunninMark] #965882
04/04/11 09:26 PM
04/04/11 09:26 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The Lincoln is a great choice, plus parts can be found, comes with discs and the bolt pattern is 4.5 just like your Mope. Less than 2 bills at pull-a-part. Get everything.
Re: Mopar IRS [Re: Cudajon] #965883
04/04/11 10:48 PM
04/04/11 10:48 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I looked into doing something like this for my 56 Dodge. I thought that the ford setup seemed clunky and modifying the width of the cradle created complications. I dont like the inboard brakes on the Jaguar setups that much. Corvette C4 components seem to be about the best option.
Here is a link to a real nice setup 57 Chevy from the tri-five website that can give you some good ideas on what can be done. There would be a fair amount of fabrication involved but its is doable.
http://www.trifive.com/forums/showthread.php?t=30205
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Mopar IRS [Re: roadrunninMark] #965884
04/04/11 10:57 PM
04/04/11 10:57 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The conquest/starion rear axle is pretty strong IIRC. I know I beat the hell out of mine lol. It had a sure grip that worked way better than anything ma mopar put out in the 60-70s as well.
68 Barracuda Formula S 340
Re: Mopar IRS [Re: Explodo] #965885
04/04/11 11:03 PM
04/04/11 11:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You should also consider track width, the LX is better suited for the 71-up B bodies, the 90's Thunderbird is better suited for early B (66-70) or 70-4 E bodies, the LX is a fragile unit in comparison to the Ford platform, theViper unit is nice, but look forward to a lot of fab to install it, as well as modding the unit itself, depending on your track requirements
Re: Mopar IRS [Re: Bad340fish] #965886
04/05/11 11:40 AM
04/05/11 11:40 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The cool thing about IRS is the ability to plant the tires without even haveing an LSD now if you add one it will really help. Think about it, the reason a live axle open rear wants to spin the right rear tire is the tq from the driveshaft is lifting that side of the axle and planting the other, with an IRS suspension the suspension moves instead of the whole axle picking up the right side. The lifting/planting action is lost in the CV axle. Even with no LSD they hook nearly as good as a straight axle.
Re: Mopar IRS [Re: HotRodDave] #965887
04/05/11 01:03 PM
04/05/11 01:03 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
That Ford rear is an 8.8 rear with 4.25 bolt circle. The cobra hubs will bolt on and give you the 4.5 you want. Not all tbirds had the 8.8, but had the 4.25 bolt pattern. The standard v6 had a 7.5. The SC v6 birds had the 8.8 traclok rear. Not all v8 birds had the 8.8 and if they did, may not have had traclok. If you go to www.sccoa.com you will get all the answers you need, including dementions.
Re: Mopar IRS [Re: roadrunninMark] #965888
04/05/11 01:40 PM
04/05/11 01:40 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
could look at the IRS in newer ford explorers, too....
2017 Grand Cherokee Overland
Re: Mopar IRS [Re: patrick] #965889
03/21/12 01:34 PM
03/21/12 01:34 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I think the C4, Dana 44 is your easiest to fab.
Granted, the trailing arms will limit tire/wheel width a little bit.
Also, the later 88-96 are a bit wider so you'll need more positive offset wheels. Or you can narrow the driveshafts and get custom tie rods/link arms from Vette Brakes.
Re: Mopar IRS [Re: slantzilla] #965890
03/21/12 01:46 PM
03/21/12 01:46 PM
hooziewhatsit Offline
https://board.moparts.org/ubbthreads/show...e=4#Post7046166
I'm friends with him, so I'll let him know there's another thread going...
Re: Mopar IRS [Re: hooziewhatsit] #965891
03/22/12 04:30 PM
03/22/12 04:30 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i have used the corvette C4 IRS in street rod projects. I have a jig set up to make the rear frame section with the attaching points for the C4 stuff. it works pretty good.
