Check the seal around the check valve sometimes they crack and leak periodically.
Turn the idle up a bit and don't pump the peddle sometimes coming up to a light/stop you can be on it and off it without realizing using up your reserve vacuum.
Also check your check valve.
then you can check the booster to see if it leaks after reving up shut off get out and see if it holds vacuum.
Check valves
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1I ran a 263/271 @ .050 cam on the street for years with no problems but kept my idle at 1100 4000 stall.
I now run a 272 @ .050 and still run my power brakes but the may get removed this season idle at 1250 5000 stall.
