How high are you turning with KB Hypers? #965260
04/03/11 05:30 PM
04/03/11 05:30 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Just curious in case I keep the 341 as a back up motor, I can put the 255/263 @.050 solid cam i just swapped out of the 414 back in (which was the original plan). I'm thinking I'd like to try a well ported high velocity set of 318 '302' closed chamber iron heads with a 1.88 or 1.94 intake just to be different.
I've heard of guys turning high 6000's low 7's with the KB's just wondering how far anyone has pushed them I planned on turning about 6600 with the E-heads.
WIZE
In Car:
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965261
04/03/11 05:49 PM
04/03/11 05:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running a set to 7600 on a 340... a rod let go
after about 1 1/2 seasons...so it wasnt a piston failure
Re: How high are you turning with KB Hypers? [Re: MR_P_BODY] #965262
04/03/11 06:13 PM
04/03/11 06:13 PM
Weddington, N.C.
Weddington, N.C.
That's great to know mr P, thanks!!
One option i have with this 3.55" stroke, 6" rod rotating assembly is you get to swap it all into a 340 block by just changing the slugs... interestingly the KB 340 flat-top is listed at the same 507 grams as the kb167 318 I have in the 341; that would be cool to swap it all into a 370-ish inch 340 motor and not even have to rebalance
7400 sounds good to me
WIZE
In Car:
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965263
04/03/11 07:37 PM
04/03/11 07:37 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Don't make any assumptions based on KB's published weights. They seem to list a standard weight for a bunch of different pistons.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: How high are you turning with KB Hypers? [Re: 471Magnum] #965264
04/03/11 07:45 PM
04/03/11 07:45 PM
Weddington, N.C.
Weddington, N.C.
That's true but the 167' were right at 507, I wouls suspect a larger and similar compression height 340 would be (if anything) a little heavier. so long as I could theoretically get the piston/pin combo to weigh the same it would be golden.
WIZE
In Car:
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965265
04/03/11 07:51 PM
04/03/11 07:51 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I once missed a shift and the playback tach said 9000 Ended up spinning a rod, but the pistons were ok..
Re: How high are you turning with KB Hypers? [Re: Jeepmon] #965266
04/03/11 08:04 PM
04/03/11 08:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I ran kb 107 hyper flat tops to 7300 all the time on a 3.58 stroke / 6.123 rod, never thought about the pistons but worried about the cast crank
Re: How high are you turning with KB Hypers? [Re: emarine01] #965267
04/03/11 09:01 PM
04/03/11 09:01 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
X2
ive gone 8200 comming out of the burnout box once or twice by mistake...this was 2 yrs ago..still going..
and i hit them with no2 on my passes..3 yrs still running.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: How high are you turning with KB Hypers? [Re: cheapstreetdustr] #965268
04/03/11 09:28 PM
04/03/11 09:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ran a set in my old 366 for 13 years and shifted at 6400/6500 for all those years,,,,motor's still running in a friend's car.
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965269
04/03/11 10:07 PM
04/03/11 10:07 PM
Az
Crizila Offline
Crizila  Offline
Az
Twist mine to 6500 regularly in my 408 with no issues so far. Although they are related, it's not the rpm as much as it is the piston speed that you have to worry about.
Fastest 300
Re: How high are you turning with KB Hypers? [Re: Crizila] #965270
04/03/11 10:11 PM
04/03/11 10:11 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've spun them 65-6700 in my Slant with spray.
Re: How high are you turning with KB Hypers? [Re: slantzilla] #965271
04/03/11 10:26 PM
04/03/11 10:26 PM
Weddington, N.C.
Weddington, N.C.
I noticed that even with the 3.91 bore 3.55 stroke the little aluminum rod 341 rev'ed a lot quicker than a lot of old "conventional" 4.04 bore, 3.31 stroke, "real" 340's I've had, I think it's not only piston speed it's ring drag associated with that piston speed as well. I had intentionally limited the powerband to 6500 with the use of a semi-mild hydraulic roller but it got there so quick it always seemed the bottom end was willing to go a lot higher....I just wanted to know HOW HIGH was 'safe'
Thanks guys, now instead of selling it I'm thinking hard about keeping it as a hot little back-up motor and using a slightly smaller solid roller in it to tweak her to go 7400 or so
WIZE
In Car:
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965272
04/03/11 11:10 PM
04/03/11 11:10 PM
Az
Crizila Offline
Crizila  Offline
Az
Any rpm before it breaks
Fastest 300
Re: How high are you turning with KB Hypers? [Re: Crizila] #965273
04/05/11 05:47 PM
04/05/11 05:47 PM
Weddington, N.C.
Weddington, N.C.
Being an aluminum rod motor but only turning 6500 I kept the quench around .042, but spinning it up another thou I need to go to a little thicker HG to allow (~.055) for stretch.
I checked with some local roundy round dirt trackers around here that are turning right at 8
WIZE
In Car:
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965274
04/05/11 06:08 PM
04/05/11 06:08 PM
Huron, South Dakota, United St...
dustyhof Offline
dustyhof  Offline
I turn mine at 74-7500 all the time. Been doing that for 10+ years now.
Re: How high are you turning with KB Hypers? [Re: Streetwize] #965275
04/05/11 07:18 PM
04/05/11 07:18 PM
organ
maximum entropy Offline
organ
apples/oranges, but a good friend of mine with a 406 shivvie ran his to 7000 plus for TEN YEARS! i don't know how many thousands of runs, but iirc, his cranking compression at the end was ~110 pounds? it didn't die- he retired it. still ran great (hard to believe).
