Re: Power steering belt problems at high rpm
[Re: Lifsgrt]
#965219
04/04/11 02:21 AM
04/04/11 02:21 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
One other reason for the question about the PS pump itself...last time it broke the best there was PS fluid on the inner fender well when I popped the hood, which came from the vent hole in the top of the filler cap. Just seems odd.
Did the fluid look aerated or bubbly? They have newer model Saginaw caps that have a rubber baffle in the step. They don't have the vent hole arrangement like the original ones have. Maybe oil comes out at high RPM and gets on the belt and then it throws?
What kind of power steering fluid are you using?
[Re: autoxcuda]
#965220
04/04/11 10:01 AM
04/04/11 10:01 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Yep, you're right. I have a brand new tuff stuff Saginaw pump and it has this rubber baffle thing on the dipstick in the filler cap. None of the others I have had came with this.
[Re: ahy]
#965223
04/05/11 09:28 PM
04/05/11 09:28 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
I'd considered slowing it with a smaller crank pulley, thanks for the reinforcement of that idea. I'll try PS fluid for a change, and I picked up a PS fluid cooler a while back for just that reason. Had not installed it yet... Thanks again fellas, will work it when I return.
