Race Front end Alignment #965182
04/03/11 02:13 PM
04/03/11 02:13 PM
OH--IO
3
360904 Offline OP
360904  Offline OP
OH--IO
This is what I come up with
Right -------- Left
camber 0 camber -1/2 degrees
caster +2 caster +2 degrees
toe 1/16 in
am I good to go?
Re: Race Front end Alignment [Re: 360904] #965183
04/03/11 02:22 PM
04/03/11 02:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, good to go. It looks like 2+ is the max caster they could get before the camber started going negative by 1/2* on the right. Your good to go.
