Need Help Tunning the HemiCar. Many Questions.
#965171
04/03/11 12:52 PM
04/03/11 12:52 PM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Just a few adjustments and this car is complete but I am stuck. 69 Hemi RR, 40 over, mild cam, auto. Everything else is stock. First off, I set the tranny kickdown according to the specs in the manual. I had the timing set at 32' and it was boggy so I now have it set at 34' and its better but the RPM's are set at 850 and they wont hold true. It jumps from 820 to 870 with and avg of 850. Will I ever get that to hold nicely on 850? Secondly, the 2 mixture screws on the rear carb. Do I crank them all the way in, all the way out, then start adjusting them together to find the smoothest idle? Whats a good starting point? Carbs are new to the car and are brand new rebuilds. Thirdly, Im not using the choke tube on my car. Do I plug that off, or leave it open for things to breathe and listen to it suck air and whistle? Sorry about the length. Eric http://img.photobucket.com/albums/v316/ericdent/006-1.jpg
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
Re: Need Help Tunning the HemiCar. Many Questions.
[Re: Dr V]
#965172
04/03/11 01:04 PM
04/03/11 01:04 PM
RapidRobert
Eric that is not a long post (you'll see). What is your initial/prob need more initial. Float levels good (what carbs) I'm not a Hemi guy so that's as far as I can go
[Re: mickm]
#965174
04/03/11 02:03 PM
04/03/11 02:03 PM
Dr V
Wattsburg, Pa
Mick, I will set the screws that way. I had no idea where to start. Without something over the choke hole it whistles like crazy. Im assuming I will have to plug it.
[Re: mikemee1331]
#965176
04/03/11 08:00 PM
04/03/11 08:00 PM
Posts: 1,019 Howell, Michigan
Hemidavey
Howell, Michigan
1 1/4 to 1 1/2 is a good place to start on the idle mixture screws. With any choke stuff disconnected...make sure it cant CLOSE when driving it!!! You'd be surprised how many cars come in my shop that can't get ot of their own way, every time you step into it they bog! 34 degrees is pretty good TOTAL advance with vaccum advance disconnected(plug the line to the carb) 12 degrees initial is good starting point. Idle won't stay perfect. HemiDave
HemiCuda Hemi Dart Hemi Coronet Hemi Roadrunner Its an illness...
