Re: low gear set, or converter [Re: tubtar] #965144
04/03/11 03:28 PM
04/03/11 03:28 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
The low gear set wasn't in any oem 727. I researched this to the nth degree years ago in between customers at Bloomington Chrysler. I also used the transmission numbers that were International Truck. The 4 pinion front planet isn't necessarially the final answer.
Re: low gear set, or converter [Re: Leigh] #965145
04/03/11 04:09 PM
04/03/11 04:09 PM
412 SB Duster Offline
The 904 is the best bang for buck. a good stock 904 with some valve body work. change the hub on the converter you have now. also the low gear set is cheap for a 904 all stock parts. 2-3 tenths easy.
Re: low gear set, or converter [Re: Leigh] #965146
04/03/11 04:53 PM
04/03/11 04:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
O.K. surprising , but good to know.
The four pinion is stronger and more desirable if I understand things , but I didn't think it was contingent on ratio.
They were truck and H.D. pieces if I recall , but I am still pretty new to the Pentastar world.
I guess I thought that a small block lugging that big tub of motorhome around would get a low 1st . gear as a matter of principal.
There are aftermarket low gear sets for the 727 ........ these come from later O.D. transmissions ?
Re: low gear set, or converter [Re: tubtar] #965147
04/03/11 05:46 PM
04/03/11 05:46 PM
upstate new york
71cuda Offline
71cuda  Offline
upstate new york
i have a 904 with a low gear set,4200 converrter,360 edelbrock heads,4.10 gear,28"dot slick,street strip car.
1.64 60' 12.20 in 1/4. so i really like the low gear set and more stall
Re: low gear set, or converter [Re: 73swinger] #965148
04/03/11 06:24 PM
04/03/11 06:24 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
sounds like a lot of cam to be done at 6200.
are the heads ported, hyd or solid, forged pistons or stock?
Re: low gear set, or converter [Re: theclutcher] #965149
04/03/11 07:21 PM
04/03/11 07:21 PM
upstate new york
71cuda Offline
71cuda  Offline
upstate new york
i have a 236/242 @.50,solid,it will pull over 6000 but i think it is out of its sweet spot,changing to a 246/252 and a m-1 single plane,26"tire,hoping for 11.80's
Re: low gear set, or converter [Re: 71cuda] #965150
04/03/11 08:47 PM
04/03/11 08:47 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Low gear set also change 2nd gear also from what I've have .
I run low gear and a 8" 4400 T.A convertor .
Yes you can get them out of certain stock transmissions .
i believe I stepped up to a aftermaket one that A&A makes now .
I run low gear set and the Coan super sprag and trans brake in both trans now .
Like most say you need to be able to take the hit and traction .
DR
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
