Re: low gear set, or converter
[Re: Leigh]
#965146
04/03/11 04:53 PM
04/03/11 04:53 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
The low gear set wasn't in any oem 727. I researched this to the nth degree years ago in between customers at Bloomington Chrysler. I also used the transmission numbers that were International Truck. The 4 pinion front planet isn't necessarially the final answer.
O.K. surprising , but good to know. The four pinion is stronger and more desirable if I understand things , but I didn't think it was contingent on ratio. They were truck and H.D. pieces if I recall , but I am still pretty new to the Pentastar world. I guess I thought that a small block lugging that big tub of motorhome around would get a low 1st . gear as a matter of principal. There are aftermarket low gear sets for the 727 ........ these come from later O.D. transmissions ?
[Re: 71cuda]
#965150
04/03/11 08:47 PM
04/03/11 08:47 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Low gear set also change 2nd gear also from what I've have . I run low gear and a 8" 4400 T.A convertor . Yes you can get them out of certain stock transmissions . i believe I stepped up to a aftermaket one that A&A makes now . I run low gear set and the Coan super sprag and trans brake in both trans now .
Like most say you need to be able to take the hit and traction . DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
