Re: 904 Shifting issues...
[Re: Mapandjlp]
#965046
04/03/11 09:37 AM
04/03/11 09:37 AM
Posts: 5,337 the house on the left.
cogen80
After some adjustments to the "kickdown" rod, I'm having some weird shifting issues. The trans now won't always shift into 3rd gear. Also, it won't shift from 3rd gear back to 1st at a stop. Could this be related to the "kickdown" (pressure) rod adjustment?
did it start only after you messed with the kickdown?
[Re: Mapandjlp]
#965050
04/03/11 04:33 PM
04/03/11 04:33 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Linkage adjustment can cause it to not shift to 3rd but linkage won't likely prevent it from downshifting at a stop.
If it hangs in 3rd at a stop but shifting to low will get 1st gear and the cycle repeats, the problem is likely a stuck shift valve or governor. The only way to know for sure is to connect a pressure gauge to the governor test port, anything over 2 psi at a stop in Drive is a governor problem. If the governor pressure is OK and it won't downshift at a stop the 2-3 shift valve is stuck.
