Holley Dominator Screen Kit??? #965010
04/03/11 03:30 AM
04/03/11 03:30 AM
Roseau, MN
1976 Aspen Offline OP
Roseau, MN
After the installation of my throttle stop, my hood scoop is no longer tall enough for my 16x2 air cleaner assembly on my Holley Dominator so I'm going to run no air cleaner at all this year. I thought I saw a post on here where somebody had a screen type setup just to keep the big stuff out. Who makes them and any pics??? I wonder if the performance will be effected with no air cleaner???
Re: Holley Dominator Screen Kit??? [Re: 1976 Aspen] #965011
04/03/11 03:59 AM
04/03/11 03:59 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Looks like I'm in the same boat as you.. So I will be watching for responses..
Re: Holley Dominator Screen Kit??? [Re: Jeepmon] #965012
04/03/11 11:04 AM
04/03/11 11:04 AM
Roseau, MN
Roseau, MN
I just found this link but WOW for expensive!!!
http://www.racingjunk.com/category/18/Co...wSuperSize=true
Re: Holley Dominator Screen Kit??? [Re: Jeepmon] #965013
04/03/11 01:25 PM
04/03/11 01:25 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Check out this uni filter, it has a screen under the red foam, my friend has one on his super comp car. Scrole down a littlehttp://www.unifilter.com/online%20catalog/automotive.html
Re: Holley Dominator Screen Kit??? [Re: formula S] #965014
04/03/11 01:48 PM
04/03/11 01:48 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Check here you can make your own using wire cloth http://www.grainger.com/Grainger/wwg/sea...&sst=subset
Re: Holley Dominator Screen Kit??? [Re: 1976 Aspen] #965015
04/03/11 02:36 PM
04/03/11 02:36 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Here's what I did. Got a Quick fuel air bell 11 inch diameter, added a K&N Extreme top 9 inch diameter. Better filtering than just screen.Fit under a 3 inch tall hood scoop. Both available at Jegs.
Re: Holley Dominator Screen Kit??? [Re: actionange] #965016
04/03/11 05:54 PM
04/03/11 05:54 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
Actionange, have you made back to back passes with and w/o that? Looks nice.
Re: Holley Dominator Screen Kit??? [Re: ProSport] #965017
04/03/11 08:19 PM
04/03/11 08:19 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Yes and it is no different from with it on to without. Used it for 4 years now when I'm not running the dual 4 bbl STR intake.
Re: Holley Dominator Screen Kit??? [Re: actionange] #965018
04/03/11 09:45 PM
04/03/11 09:45 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
AWESOME... Thats thinking outside the box
Re: Holley Dominator Screen Kit??? [Re: Jeepmon] #965019
04/04/11 10:05 AM
04/04/11 10:05 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Here's another example that I stumbled across while looking at plug wires https://www.customwiresets.com/product.php?productid=16271&cat=304&page=1
Re: Holley Dominator Screen Kit??? [Re: actionange] #965020
04/04/11 11:12 AM
04/04/11 11:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I like what you did. You say there was NO difference in ET / MPH between the basic carb bell and when the K&N X-stream lid was added? What sort of times is that car running? And do you have that setup sealed to a hood scoop?
Re: Holley Dominator Screen Kit??? [Re: 1976 Aspen] #965021
04/04/11 02:46 PM
04/04/11 02:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
lol....that one pic looks familiar!
Mopar Performance
Re: Holley Dominator Screen Kit??? [Re: 1976 Aspen] #965022
04/04/11 04:42 PM
04/04/11 04:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just buy a short stack and wrap the screen around to
the back and use JB Weld to glue it in place... you
can glue a grommet in the center for the hold down
Re: Holley Dominator Screen Kit??? [Re: BradH] #965023
04/04/11 05:29 PM
04/04/11 05:29 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
There was no difference from running with a no filter and no air bell to putting what you see in the pic. Car runs between 10.27 to 10.31 at 132 to 132.50 in spring and/or autumn condition.
It is not sealed to the hood scoop.
Re: Holley Dominator Screen Kit??? [Re: actionange] #965024
04/04/11 07:55 PM
04/04/11 07:55 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
here is mine made it myself about 35.00
Re: Holley Dominator Screen Kit??? [Re: MOPARCHAS] #965025
04/04/11 07:56 PM
04/04/11 07:56 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
another angle
Re: Holley Dominator Screen Kit??? [Re: MOPARCHAS] #965026
04/04/11 08:09 PM
04/04/11 08:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
MoparChas..give us the"scoop" on it's construction...it looks very nice.
Nautilus Racing-
Re: Holley Dominator Screen Kit??? [Re: Chris2581] #965027
04/04/11 09:27 PM
04/04/11 09:27 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
found the air bell at a swap meet 20.00
used mesh screen from home depot 10.00
the chrome trim around the top is nothing more than door edge guard 5.00
something else I made out of 6160 aluminum tubing for your roll bar to keep from messing up the paint
Re: Holley Dominator Screen Kit??? [Re: actionange] #965028
04/05/11 10:56 AM
04/05/11 10:56 AM
BradH Offline
BradH  Offline
Cool... I wasn't able to find any flow data specific to the Xtream lids by themselves and was wondering if running only the lid like you show would cause a restriction. It must work OK based on your results.
Re: Holley Dominator Screen Kit??? [Re: actionange] #965029
04/05/11 11:40 AM
04/05/11 11:40 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
This is a really good idea. I need a bigger scoop or a 4500 intake without the 2" adaptor. Does the 9" top seem to flow enough air through it? Do the carb vent tubes clear the bottom or did you have to cut them off a bit? Looks good Im going this route for sure!
67' charger 499 RB 10.57 at 127
