Advance / Retard Cam???? #964946
04/03/11 12:32 AM
04/03/11 12:32 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
I have an Edelbrock adjustable timing chain on my 360, and the timing cover off...if I wanted to improve the lower end, woudl I advance or retard that cam.
The timing chain alows, 3 degree of adjustment either way.
Should I worry about the valve to piston clearance (I am running the stock dished pistons)?
Here are my current specs:
74 Cuda with a 360,
Eddy torker II intake,
Eddy torker Plus cam,
The specs are as follows:
@050 Int dur. 222 , Ex dur. 234
Lift Int .447 Ex .450
Intake Centre line 107 Ex centerline 116.
About 9:1 compression.
Holley 750 vac secondary carb.
Dizzy has been recurved, running 20 initial, 38 total all in before 3000.
727 with stock converter (I know -its on the list!)
8-3/4 with 3.22s
Thanks!
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964947
04/03/11 12:49 AM
04/03/11 12:49 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
advance
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964948
04/03/11 12:50 AM
04/03/11 12:50 AM
Advance it & I'm confident you're good but if I'm reading this right you've checked/ran it straight up already?
Re: Advance / Retard Cam???? [Re: RapidRobert] #964949
04/03/11 12:58 AM
04/03/11 12:58 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Yep... ran it straight up for years. No issues, but low end could be better. I am concerned with the valve timing if I adavnce it.
Jason
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964950
04/03/11 01:06 AM
04/03/11 01:06 AM
Jason I would go ahead. Those pistons are way down there but for peace of mind/doing thing professionally you could take off a pair of springs w an on eng spring compressor & check
Re: Advance / Retard Cam???? [Re: RapidRobert] #964951
04/07/11 10:24 PM
04/07/11 10:24 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
I don't know....I think I will just leave it as is...it runs good, so why play with it and run the risk of screwing it all up!
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964952
04/07/11 11:47 PM
04/07/11 11:47 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Cudajas,Hope I can change your mind, With that mild cam,go ahead and advance it,you will be glad you did!!
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964953
04/07/11 11:49 PM
04/07/11 11:49 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I just went through the degreeing exercise with my 408 stroker. Advancing it will improve the top end but only by a few hundred RPM. You probably wont feel (or see on a dyno) any change less than 2 degrees. If you dont feel the low end is good enough advancing it wont help. Id be afraid to retard it beyond straight up. Remelner if toy are adjusting the crank gear retarding at the crank advances the cam. Advancing at the crank retards the cam.
You may also want to check the original cam card, if may already have a certain amount of advance built in.
A higher stall converter might give you better results.
Good luck,
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Advance / Retard Cam???? [Re: Magnum] #964954
04/08/11 03:24 AM
04/08/11 03:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
advance
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964955
04/08/11 10:33 AM
04/08/11 10:33 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
74 Cuda with a 360,
8-3/4 with 3.22s
Thanks!
that cam already has 5 degrees advance ground into it. why advance it more? i'd change the intake to a dual plane.
Re: Advance / Retard Cam???? [Re: lewtot184] #964956
04/08/11 10:40 AM
04/08/11 10:40 AM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
with your Timing cover allredy off, why dont you go ahead and do a compression test on it as is, then advance it and do another compression test and compare them?if you see a noticable increase, then you should see more TQ.
Re: Advance / Retard Cam???? [Re: Tom Fox] #964957
04/10/11 11:19 AM
04/10/11 11:19 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
hmmmm..tha sounds like a good idea.
So...if I advance the cam and have higher cranking compression, it would make sense to leave it advanced. If not set it back to stright up.
Of course it could alos highlight other issue with the engine...and that would suck!!!
So no issue cranking the engine with the timing cover and damper off???
Jason
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964958
04/10/11 11:50 AM
04/10/11 11:50 AM
So...if I advance the cam and have higher cranking compression, it would make sense to leave it advanced. correct
Of course it could alos highlight other issue with the engine...and that would suck!!! what issues
You'll have the cam bolt/washer/eccentric on & no prob just for a compression test, the crank gear wont go anywhere and as you know adv/ret it will change P/V clearance
Re: Advance / Retard Cam???? [Re: RapidRobert] #964959
04/10/11 12:18 PM
04/10/11 12:18 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Of course it could also highlight other issue with the engine...and that would suck!!! what issues
thanks, yep the bolt and ecentric would be on.
Other issue...well I have not done a compresion check on the engine since I put it the car back on the road...and although it runs well...it does not run as strong as I would like (could be the overall combination of engine gearing etc.). But at this time I prefer to be blissfully unaware of any underlying issues that would dictate an full engine rebuild.
Good thing I am an optomistic kind a guy eh???? Who knows, everything might check out ok!
jason
Re: Advance / Retard Cam???? [Re: CUDAJAS] #964960
04/10/11 12:47 PM
04/10/11 12:47 PM
Yes a good basic compression test will tell you ballpark if the long block is healthy (ring seal/piston wear/cam lobes) and if it's combo of parts (piston CR/cam choice/head CC) is acceptable. Then that leaves the rest of the eng (intake/carb/ex/timing and the car itself (TC/weight/gearing. Want to narrow the prob down. Good luck w it.
