race car wiring ????? #964915
04/03/11 12:02 AM
04/03/11 12:02 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
hey guys I am getting ready to rewire my car, not sure what size wire to use 12,14, gauge for stuff like electric fuel pumps and electric water pump and fan.....THANKS IN ADVANCE
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: race car wiring ????? [Re: 67mprfan] #964916
04/03/11 12:08 AM
04/03/11 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well it makes a difference... some things draw HEAVY
amps(some fans draw as much as 40 amps)... will
you be using relays on the stuff
Re: race car wiring ????? [Re: MR_P_BODY] #964917
04/03/11 12:22 AM
04/03/11 12:22 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
hey mike didn't really think about relays the switch panel i have uses fuses but now i need to give that some thought..btw none is in the car now ......THANKS
Re: race car wiring ????? [Re: 67mprfan] #964918
04/03/11 12:27 AM
04/03/11 12:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Guage will vary with a variable of things. Length, componets, relays, heat of the compartment.
Things like gauge lights and ignition source indicater wires can use 20 gauge. Water pumps, Fans and fuel pumps, may need 10 gauge or better depending length from power source.
But in most cases 12 gauge is plenty. Instead of having heavy gauge wiring running around everywhere I would use relays for remote locations. If you have a high draw short length wired componet use a HD switch with a matching wire gauge.
Dont rely or trust your typical/elcheapo 20 amp switchs that you might get at your local auto retail shops. They by far dont handle the amps they are advertised at.
Re: race car wiring ????? [Re: Sport440] #964919
04/03/11 12:52 AM
04/03/11 12:52 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
at the moment just looking at the fuel pumps to the switch panel as it being a race car batt's in the trunk, pumps in the rear, there is no motor so the up frt wiring has to wait.btw using arc panel if that helps
Re: race car wiring ????? [Re: 67mprfan] #964920
04/03/11 12:59 AM
04/03/11 12:59 AM
Arizona
Chris'sBarracuda Offline
Arizona
I am putting this in my junk when it gets back from paint JAIL..
I currently have ARC system.. Which I like a lot, but couldn't pass up my deal on this..
Gil Zeneri.. @ Speedwire Systems..
http://www.gallo-teck.ca/speedwire/products.htm
Chris..
Re: race car wiring ????? [Re: Chris'sBarracuda] #964921
04/03/11 01:10 AM
04/03/11 01:10 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
should i use relays with the arc switch panel
Re: race car wiring ????? [Re: 67mprfan] #964922
04/03/11 01:17 AM
04/03/11 01:17 AM
Arizona
Arizona
Check out Auto Rod Controls on the web..
But here is a video.. They use a relay block/panel..
http://www.youtube.com/watch?v=XAxpsVLJvoo
Chris..
Re: race car wiring ????? [Re: 67mprfan] #964923
04/03/11 01:40 AM
04/03/11 01:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats definatly a situation where you want to use a relay. Id put the relay in the trunk.
That way the pumps power feed will be a very short distance. Batt to pump through the relay.
VS sending power to the front first and then back to the back with a even larger wire gauge preferred or needed.
In this case you can energize the relay two ways.
You can send 12 volts to it from your arc switched panel. Or you can ground it from the front or through the arc panel if it has that capability.
To keep it simple I wouldnt use anything less then 12 gauge to feed the pump. To engergize the Relay from front to back. You could use 20 gauge or higher. A relay takes Miliamps to energize.
But instead of buying a a bunch of different gauge wireing sizes. 12 and 16 gauge spools should cover you. But, also take into consideration wire color for easier polarity identification.
Re: race car wiring ????? [Re: 67mprfan] #964924
04/03/11 07:21 AM
04/03/11 07:21 AM
Q
Quicktree Offline
Quicktree  Offline
Q
do yourself a favor and get a kit from painless wiring or one of the other companies. and find somebody with wiring experience to help or do the job.anyoone can string a bunch of wires but there are things that need to be done to make it safe and work properly. if you have to ask these questions it makes me wonder if you know these things. not being rude just saying. good luck
Re: race car wiring ????? [Re: Sport440] #964925
04/03/11 11:52 AM
04/03/11 11:52 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Is your battery in the trunk? Are you going to run an alternator?
If so how many amps will it be sending 15' or so to the batt.?
I think I use a 4 ga. wire for my alt. to batt. in trunk. 100 amps could melt a 10 ga. wire 15' long.
There are sites or books that tell you what gauge wire for how many amps going what length.
Don
Re: race car wiring ????? [Re: 67mprfan] #964926
04/03/11 12:08 PM
04/03/11 12:08 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
should I use relays with the arc switch panel
YES
Here is a chart to give you a better idea on what wires to use where. The "length" referred to is a total of both the hot and ground wires to the item.
Scotty
Re: race car wiring ????? [Re: Quicktree] #964927
04/03/11 09:29 PM
04/03/11 09:29 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
do yourself a favor and get a kit from painless wiring or one of the other companies. and find somebody with wiring experience to help or do the job.anyoone can string a bunch of wires but there are things that need to be done to make it safe and work properly. if you have to ask these questions it makes me wonder if you know these things. not being rude just saying. good luck [/quote
no i didn't take it wrong i seen them done both ways i bought the car a yr ago and started stripping wires out(msd, delay box,and now fuel pumps)and didn't find and relays in the car
Re: race car wiring ????? [Re: 67mprfan] #964928
04/04/11 08:17 AM
04/04/11 08:17 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I just rewired my 4th car. Put in the ARC 8000R touch panel.
It comes with a relay board that plugs in to the switch panel.
Absolutely love it.
Besides the heavy current users (starter, battery, etc.) I run everything in 14 gauge mtw wire.
Why does divorce cost so much? Because it is worth it!!!!!
Re: race car wiring ????? [Re: mopar376d] #964929
04/04/11 07:46 PM
04/04/11 07:46 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I'm installing an ARC 8000D panel right now and it couldn't be any easier.
