Boosted Racing Engines: I got a question?
#964580
04/02/11 05:42 PM
04/02/11 05:42 PM
Posts: 577 Arkansas
Adrielp
Arkansas
So as I asked a question about valves on the race only forum, that got me thinking about the size of valves in a boosted engine, specifically when it comes to the intake to exhaust ratio. I know that NA engines like bigger intakes and smaller exhaust when making max power per cubic inch but in terms of boosted engines, I don't really know.
So in racing boosted applications, what type of intake to exhaust ratio do these engines like. In a theoretical sense it seems they might need to have a little bigger exhaust to get things out of cylinder more quickly. I'm sure some of the boosted gurus on here can answer this question. Thanks in advance guys!
Adriel Paradise Substation Design Engineer III
Re: Boosted Racing Engines: I got a question?
[Re: blownzoom440]
#964582
04/05/11 11:26 AM
04/05/11 11:26 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
You will want a bigger exhaust valve compared to a NA engine. I run a 1.625 ex and 2.225 intake on my w8 turbo motor. Alot of the NA w8 ex valves are in the 1.55 range.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: W8n2DustU]
#964583
04/05/11 11:30 AM
04/05/11 11:30 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
The sizing is not your only worry in a boosted application. You need to use a nice valve from quality material. .
One day I will have something cool here.
[Re: sdaurity]
#964584
04/05/11 06:31 PM
04/05/11 06:31 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
True. Exhaust valves have hard lives in turbo engines.
[Re: Adrielp]
#964587
04/11/11 02:44 AM
04/11/11 02:44 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
There's a lot of theories on this, most of them not very well thought out. An engine doesn't know it's boosted. It only sees pressure differentials. So let's say you add 15 lbs of boost to the intake manifold. That's a total of 15 plus your atmospheric which is dependent on elevation, barometer and a few other things. So you shove that mixture in past the intake valve, it closes and BOOM! Now how much pressure do you think is coming out the exhaust? The more air you get into an engine, the more air you will get out of it. Plain and simple. Does this mean I wouldn't port on the exhaust side because I don't think it's as important as the intake? No. That is not what I'm saying. I'm simply saying don't choke the intake in an attempt to make the exhaust better. You will find that if you pick up the intake flow and nothing else, your boost will go down, the intake temps will go down AND you'll make more power. Boost is, after all, a measurement of restriction. And definitely put the best valves you can afford in that puppy.
[Re: dodgeboy11]
#964588
04/11/11 10:42 PM
04/11/11 10:42 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Big exhaust valves allow some important things in a turbo engine. First, exhaust flow at the valve is only as important as you make it. Having the flow capacity in the head is useless unless you are using a good flowing downstream system.(headers/turbine/wheel)A good flowing head with bias on the exhaust, combined with a complimenting downstream system will allow the use of a camshaft with more characteristics of a n/a cam. Another advantage is valve cooling. Most of the valve cooling is thru the valve seat. With more surface comes more contact, and with that comes a better cooling, which allows longer durations(less seat time) with adequate valve temps.
