340 manifold on 318 problem? (pics inside)
#964472
04/02/11 04:28 PM
04/02/11 04:28 PM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
today i'm finally getting around to finishing my winter project and decided to practice putting the manifold onto the heads so i dont screw up the gasket mating process. this may be common knowledge, but i noticed the manifold matches up port and bolt wise, but there is still surface showing where the 318 intake manifold covered that the 340 manifold leaves exposed. is this ok?
also, the little bendy metal tabs (4 pairs total), do they need to be in the up position or down? it was recommended to me to NOT use the supplied front and rear gasket and just seal it up with some permatex "right stuff" sealant.
remember, this is all new to me and figured this little project will teach me some engine work basics.
thanks
73 Road Runner
09 Challenger R/T
Re: 340 manifold on 318 problem? (pics inside)
[Re: stumpy]
#964475
04/02/11 04:34 PM
04/02/11 04:34 PM
bigdaddywiz
Pittsburgh, PA
When you look at your intake gasket end pieces you will see where the metal tabs go. They help hold the gaskets in place.
oh, ok...thanks! didnt even think of that...i thought those were for the front and rear gasket...duh!
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#964476
04/02/11 04:45 PM
04/02/11 04:45 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Yep looks right from here.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#964478
04/02/11 05:01 PM
04/02/11 05:01 PM
RapidRobert
Actually you want those "horseshoe" opening on each side to b open for heat to not affect or b wicked off to the adjacent ports. I would suggest you use a wide carefully placed swath of silicone (clear is barely noticeable) at each end instead of the supplied gaskets as they in a lot of cases are a bit too thick & can hold the intake up a bit causing one of the front manifold water ports to leak after a period of time. If so let it sit up overnight then fire it up & if not at least mockup & see how thick of end gaskets you were given & go from there. Some of those cork gaskets are real thick. Dont know if you have done any milling that would ch your heights. Prob overkill (I'm like that) but never hurts to check
[Re: AARCONV]
#964483
04/02/11 09:51 PM
04/02/11 09:51 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
the fel pro gasket will cover the horseshoe part also
You don't want this covered. It is to keep a cooler air flow dam between to hot exhaust valve castings. It is designed to be open. Over heated valve seats = cracked valve seats.
[Re: 340SHORTY]
#964484
04/02/11 10:02 PM
04/02/11 10:02 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
you do relize that there is a large port size difference between a 318 and a 340/360 ?
The factory used a 360 intake on the 318s with 318 heads. There's a Mopar racer that ran one in Stock. His engine builder said it would never be fast with the mismatch ports. His 'never will be fast' combo set the record in T/SA at the first points meet he went to, qualified #1 and won the Gatornationals, runner up'ed the Summernats and won a Div 2 race.
[Re: B5 Bee]
#964485
04/03/11 02:07 AM
04/03/11 02:07 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
The factory used 360 intakes on 318s with 360 heads.....
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: bigdaddywiz]
#964487
04/03/11 12:32 PM
04/03/11 12:32 PM
Posts: 314 North East Missouri
express
North East Missouri
These are for the front & rear foam or cork seals,but you are not using them so just silicone them down.
[Re: 69L78Nova]
#964490
04/03/11 03:22 PM
04/03/11 03:22 PM
B5 Bee
Pangaea
That's true, most 318-4 had 360 heads, but they also used 360 intakes on 318s with 318 heads. The 360 head 318 motor has a higher NHRA HP factor. He ran the small head because it had the most favorable HP factor. It didn't last long, NHRA added HP to the small head 318-4 by the end of that year which moved his car up a class from T/SA to R/SA (there is no S/SA).
