thread sealer where? #964320
04/02/11 12:00 PM
04/02/11 12:00 PM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
i'm installing my intake manifold finally along with the water pump...will i need thread sealer on the water pump bolts too? i know i need them on the intake manifold, right?
thanks
73 Road Runner 09 Challenger R/T
Re: thread sealer where? [Re: bigdaddywiz] #964321
04/02/11 12:05 PM
04/02/11 12:05 PM
Kirkland, Washington
Pacnorthcuda Offline
SB or BB?
Re: thread sealer where? [Re: Pacnorthcuda] #964322
04/02/11 12:10 PM
04/02/11 12:10 PM
Pittsburgh, PA
Pittsburgh, PA
SB or BB?
i'm a noob...what do those stand for?
Re: thread sealer where? [Re: bigdaddywiz] #964323
04/02/11 12:14 PM
04/02/11 12:14 PM
Small Block or Big Block? What engine are you working on?
Re: thread sealer where? [Re: Pacnorthcuda] #964324
04/02/11 12:15 PM
04/02/11 12:15 PM
Pittsburgh, PA
Pittsburgh, PA
ooohhhh ok
its a 318 block...i'm installing a manifold off a 340 for a small upgrade...
thanks
Re: thread sealer where? [Re: bigdaddywiz] #964325
04/02/11 12:19 PM
04/02/11 12:19 PM
Water pump bolts--yes. Intake manifold--someone else can answer (I am more of a BB guy) but when in doubt? Yes. I believe you risk oil seepage if you don't.
But again somebody else can confirm/correct.
Re: thread sealer where? [Re: bigdaddywiz] #964326
04/02/11 12:24 PM
04/02/11 12:24 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Really only need it on the 4 bolts that are to the left and right of the carb flange, but to be safe, just do 'em all. Never hurts.
And thread sealer is cheaper than having to clean the engine and re-seal the bolts.
Good Luck,
CC.
Re: thread sealer where? [Re: chargincharles] #964327
04/02/11 12:30 PM
04/02/11 12:30 PM
Pittsburgh, PA
Pittsburgh, PA
thanks guys. everyones always a big help here...and quick!
Re: thread sealer where? [Re: bigdaddywiz] #964328
04/02/11 12:37 PM
04/02/11 12:37 PM
Permatex #3 w the brush in the can on the WP bolts works good
