Powerglide ultra bell question? #964301
04/02/11 10:49 AM
04/02/11 10:49 AM
KY
juicedcuda Offline OP
KY
I am running a Autozone part # 5.9l starter and was wondering if I need to run the shims and bushing supplied with the jw ultrabell kit when putting a Powerglide behind a bb Mopar.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Powerglide ultra bell question? [Re: juicedcuda] #964302
04/02/11 10:58 AM
04/02/11 10:58 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i used the summit mini starter and i used 3 shims with the glide. look at the clearance of the ring gear to the starter and that will help you determine the ammount of shims. the turbo 400 that i just took out used two. the glide took three. with three shims i did not have to use the aluminum sleeve that jw gives you. i also replaced the 8 gold grade 8 bolts that they give you with some arp shoulded bolts.
Re: Powerglide ultra bell question? [Re: juicedcuda] #964303
04/02/11 11:01 AM
04/02/11 11:01 AM
ky
68roadrunner Offline
ky
i shimmed mine to make a full tooth contact with ring gear.
i think i used 4 shims and the spacer.
Re: Powerglide ultra bell question? [Re: 68roadrunner] #964304
04/02/11 12:25 PM
04/02/11 12:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes on the shims here as well...
Re: Powerglide ultra bell question? [Re: juicedcuda] #964305
04/02/11 12:56 PM
04/02/11 12:56 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I had too use 1 shin too
Get perfection
