ok guys I worked on it today. It only had a little bit of water in it. This is the third time I changed the oil and now it's good. I broke in the cam correctly and set it at idle today. I had to check the valves a bunch but it's pretty much all good now.
I did have another question for you guys while we're at it... When my last engine stopped working it's because it was detonating... I'm wondering what jet sizes you recomend? And where I should set the timing...
this is what it is
360 $2,000 in machine shop work
ported heads 2.02in 1,60ex
.522" custom cam 107 lobe centers.... solid
kb107's so it should be about 10.5-1 compression
victor jr. intake some plenum work and port matched
holley 750 double pumper
msd distributer and digital 6
8 3/4 rear end minitubbed 3.91 gears 275 drag radials
I think I have it at 35* now not too sure on the jet sizes gonna check that tomorrow
thanks
