I still have pinging problems with my 512
#964119
04/02/11 01:32 AM
04/02/11 01:32 AM
Posts: 659 Boise Idaho
Boise Chall
Boise Idaho
the 512 in my 72 Challenger is still pinging on me. The motor is a 512 stealth aluminum heads Holley 950 HP carb Comp cams XE295HL-10 cam, 11.3:1 compression, MSD 6Al, MSd Billet distributer, 3,200 Rpm Stall,2"TTI headers, 3" pipe to 3" Flowmaster 40 series , 3:55 gears. Timing is 16 initial 32 total all in by 2,800 RPM. The pinging occurs at about half throttle and it's a pretty loud ping The things I have done to try to solve the problem are
1. Brought the timing down from 34 total to 32 total 2. Upped the primary jets 4 sizes 3. increased the power valve from 2.5 to 3.5 4. Added 5 gallons E85 ( 110 Octane )to 10 gallons of 91 octane 5. went up 2 heat ranges on my plugs
Nothing helped at all I'm at a loss on this problem. Could it be that I'm bringing my timing in too soon? if all of my timing is in at 2,800 and my stall is 3,200 could I be too far advanced when the stall comes in? My engine temps are 185-190 and pretty steady, At this point I'm willing to try anything. I prefer not to tear the motor down but at this point if I need to I will before the pinging tears the motor apart for me.
Re: I still have pinging problems with my 512
[Re: Boise Chall]
#964128
04/02/11 09:05 AM
04/02/11 09:05 AM
Posts: 7,664 IN
ahy
IN
Comment on the E85 - it is high octane but lower energy per gallon. Adding it to the fuel mix effectivly leans out the mixture. Even with the bigger jets you may have leaned it out overall with the E85. Two or three gallons of 110 race gas added to pump premium should help without leaning the mixture. That and reading the plugs and likley going to a colder plug should quiet it down.
Also, ping at half throttle suggests the timing curve is too aggressive. A slow mechanical advance with full advance delayed to 3000 RPM may help.
The other benefit of adding the race gas is it should run without hurting itself while you get the plugs, timing and mixture dialed in.
[Re: Boise Chall]
#964130
04/02/11 09:31 AM
04/02/11 09:31 AM
Posts: 75,006 U.S.S.A.
JohnRR
U.S.S.A.
I don't know my Cranking pressures. Maybe that's why I can't solve this problem I don't know the important info like pressures and piston height
Who built this engine ? you need to know what you are dealing with.
Also what or who gave you the idea to dump E85 in there ? It's not the same as mixing in 110 race gas. You either build it to run on E85 , or on Gas , you can't really mix the 2 , but the fact that you have e85 you might want to think about converting to it .
[Re: Boise Chall]
#964131
04/02/11 10:36 AM
04/02/11 10:36 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Put a compression tester on it and find out what it's cranking. E85 is not what you need to increase pump premium's octane. To effectively increase your octane, try running some % of 100 octane unleaded or add 110 octane leaded to your tank. You will have to rejet no matter what you do when you start blending your fuel, so be consistent with the mixture once you get a ratio that works. You may want to get a knock sensor to detect detonation and a wideband with data logger. FAST has a nice wideband unit.
I only drive my car for fun and rarely burn more than a tankful a month, so I intentionally opted for high compression (12.8 to 1 @ 225psi cranking). I've always liked how it runs with it, and I don't really care about the cost difference to run high compression because of the performance trade off. I don't drive the car that much. Also, I know you can't get 100 octane unleaded everywhere, so I had a larger tank made to extend my cruising range. I do have to pay about 1/2 again more for each gallon of the fuel to meet the octane requirements. I was going to mix 110 octane unleaded, but that's illegal in California now. Fortunately, my motor likes the 100 octane unleaded at about $6.50 a gallon.....and rising, but I knew this going in. Sounds like you didn't know your compression is too high for normal pump gas.
[Re: DAISYDUSTER]
#964134
04/02/11 12:52 PM
04/02/11 12:52 PM
Challenger 1
Cincinnati, Ohio
Like what a few guys have already said, get rid of that swill gas you have now, and put some real gas in it. I'm betting the compression is higher than you think. 0 deck? I would have CC the engine after I had the heads on, when I put it togeather so I knew for sure what the compression is. Get good gas first. Like what already said, I'd start with a straight 110 leaded. You maybe be able to blend down from there, but at 11+-1 gonna need more than prem pump gas. Hopefully you have someone nearby who sells race gas at the pump or buy it by the drum. Speed and horsepower cost $$ We have a place nearby that sells 100 octane unleaded and 110 leaded at the pump, makes it nice.
