360 Cam Selection Help... #963910
04/01/11 06:41 PM
04/01/11 06:41 PM
Middle River, MD
Mapandjlp Offline OP
Middle River, MD
Ok, I've finally had enough with this Thumpr cam. Too much for me.
I'm after a cam that will give me a LITTLE LOPE, not sound like a funny car. It must work with my A/C, auto trans (175k converter), and not shake the welds on the car loose. This is a cruiser, not a race car.
'70 Challenger
360 + .030
KB107 Pistons
596 Heads
Performer Intake
Edelbrock AVS 650 carb
Orange ECU
Headers + 2.5" exhaust with 40 series mufflers
2.76 gears at the moment but will be 3.23
I'll take your suggestions on a cam now...
Oh, and I know where you can score a slightly used Thumpr cam...
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963911
04/01/11 08:46 PM
04/01/11 08:46 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963912
04/01/11 08:48 PM
04/01/11 08:48 PM
ill
dennismopar73 Offline
ill
280 480 will do you good
even a 270 h comp what i ran on the street
rum high 12-low13 in 3200 car
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963913
04/02/11 04:40 AM
04/02/11 04:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a Hughes HEH1523AL cam in my 360 RV engine and it's pretty mild at idle, but makes good power.
With your higher compression you could even use a bigger cam. It's the wider lobe seperation that reduces the overlap and helps the engine idle smoother.
I would suggest the Hughes HEH1928AL cam, 219/228 duration @ 0.050, 0.489"/0.524" lift, 111 LSA installed at 108.
This would compare to the 262 duration Voodoo cam, 220/226 @ 0.050", 0.475"/0.494' lift, 112 LSA installed at 108.
Or the Comp "XE262H", 218/224 @ 0.050", 0.462"/0.470", 110 LSA installed at 108.
Going with the next larger sized cam you may have to run a higher stall converter, and/or more gear.
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963914
04/02/11 10:17 AM
04/02/11 10:17 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
The 360 in my Challenger conv is close to what you have. 360 + .030 with KB 107's, LD340 intake,340 HP exhaust manifolds, Hemi J converter, 3.23 sure Grip. Mine has this MP Purpleshaft cam in it, and it's perfect for this motor. http://www.summitracing.com/parts/DCC-4452761/
Re: 360 Cam Selection Help... [Re: JDMopar] #963915
04/04/11 09:45 AM
04/04/11 09:45 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
comp XE262 or the above mentioned lunati voodoo cam.
2017 Grand Cherokee Overland
Re: 360 Cam Selection Help... [Re: patrick] #963916
04/04/11 06:34 PM
04/04/11 06:34 PM
Ormond Beach, FL
71STROKERFISH Offline
Ormond Beach, FL
I'm running a MP 280/.474 in my stroker 360.....sweet mellow lope, very driveable. Runnning a hwy gear and 28-3200 stall....very good cam....
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: 360 Cam Selection Help... [Re: 71STROKERFISH] #963917
04/04/11 07:00 PM
04/04/11 07:00 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
or a XE268H
if that is too much for you then the XE262.
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963918
04/04/11 11:56 PM
04/04/11 11:56 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I was very happy with the mopar .450/.455 cam and similar gears in a 76 (ie, heavy) valiant...good idle, good vacuum, got into the 13's with 2.94 gears....not too shabby.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 360 Cam Selection Help... [Re: Prince_Valiant] #963919
04/05/11 04:32 PM
04/05/11 04:32 PM
P
Paul_Fancsali Offline
P
Comp 268 cheap and powerful run the gear you have now
1968 340 manuel spec cam from racer Brown runs like scalded rabbit
Comp 280 real good power higher end needs gear 3.91 or better
Re: 360 Cam Selection Help... [Re: Paul_Fancsali] #963920
04/05/11 05:09 PM
04/05/11 05:09 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I'd second the XE268. I run it my own similar 360. I have 3.91's now, but I ran it for about a year with 2.76's and it was still no dog.
It lopes a little when cold, but sounds pretty mild when warmed up.
Re: 360 Cam Selection Help... [Re: 440newport] #963921
04/05/11 07:51 PM
04/05/11 07:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I have a Scott Brown 268/285 in my 9:1 360, it's the same way, sounds mean (for the street)when cold , then tame once it warms up. '68 Barracuda with 9.5" converter and 3.55 SG. When it ran 13.75, it was suffering from fuel starvation, undiagnosed at the time. Want to get it back to the track this spring, should be 13.5 or lower if I can hook.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 360 Cam Selection Help... [Re: GO_Fish] #963922
04/12/11 08:34 PM
04/12/11 08:34 PM
Middle River, MD
Middle River, MD
So the XE268 seems like the winner here. Anyone have any experience with this cam, automatic trans, and A/C?
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963923
04/12/11 11:46 PM
04/12/11 11:46 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
k, so i am chiming in as i am getting a 360 built. Going with flat top pistons and 70 340 spec cam. Hoping that this should make some good power, idle with a bit of lope to it, but nothing wild. Will be using a stock stall converter, with 3.23:1 gears. . . .
Re: 360 Cam Selection Help... [Re: Mapandjlp] #963924
04/13/11 09:02 AM
04/13/11 09:02 AM
Tampa, Fl.
tampacuda69 Offline
tampacuda69  Offline
Tampa, Fl.
CompXE268 in my 340. Auto, A/C, 3.23 Sure Grip. love it, great all around street cam. Plenty of bottom end, nice highway cruise.
