360 Cam Selection Help...
#963910
04/01/11 06:41 PM
04/01/11 06:41 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
Ok, I've finally had enough with this Thumpr cam. Too much for me. I'm after a cam that will give me a LITTLE LOPE, not sound like a funny car. It must work with my A/C, auto trans (175k converter), and not shake the welds on the car loose. This is a cruiser, not a race car. '70 Challenger 360 + .030 KB107 Pistons 596 Heads Performer Intake Edelbrock AVS 650 carb Orange ECU Headers + 2.5" exhaust with 40 series mufflers 2.76 gears at the moment but will be 3.23 I'll take your suggestions on a cam now... Oh, and I know where you can score a slightly used Thumpr cam...
Re: 360 Cam Selection Help...
[Re: Mapandjlp]
#963912
04/01/11 08:48 PM
04/01/11 08:48 PM
Posts: 2,177 ill
dennismopar73
ill
280 480 will do you good even a 270 h comp what i ran on the street rum high 12-low13 in 3200 car
[Re: Mapandjlp]
#963913
04/02/11 04:40 AM
04/02/11 04:40 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have a Hughes HEH1523AL cam in my 360 RV engine and it's pretty mild at idle, but makes good power. With your higher compression you could even use a bigger cam. It's the wider lobe seperation that reduces the overlap and helps the engine idle smoother. I would suggest the Hughes HEH1928AL cam, 219/228 duration @ 0.050, 0.489"/0.524" lift, 111 LSA installed at 108. This would compare to the 262 duration Voodoo cam, 220/226 @ 0.050", 0.475"/0.494' lift, 112 LSA installed at 108. Or the Comp "XE262H", 218/224 @ 0.050", 0.462"/0.470", 110 LSA installed at 108.
Going with the next larger sized cam you may have to run a higher stall converter, and/or more gear.
[Re: Mapandjlp]
#963914
04/02/11 10:17 AM
04/02/11 10:17 AM
Posts: 8,485 Candler,NC / Myrtle Beach, SC
JDMopar
The 360 in my Challenger conv is close to what you have. 360 + .030 with KB 107's, LD340 intake,340 HP exhaust manifolds, Hemi J converter, 3.23 sure Grip. Mine has this MP Purpleshaft cam in it, and it's perfect for this motor. http://www.summitracing.com/parts/DCC-4452761/
[Re: JDMopar]
#963915
04/04/11 09:45 AM
04/04/11 09:45 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
comp XE262 or the above mentioned lunati voodoo cam.
[Re: patrick]
#963916
04/04/11 06:34 PM
04/04/11 06:34 PM
Posts: 568 Ormond Beach, FL
71STROKERFISH
Ormond Beach, FL
I'm running a MP 280/.474 in my stroker 360.....sweet mellow lope, very driveable. Runnning a hwy gear and 28-3200 stall....very good cam....
-dc SOUTHERNPLAINSMOPAARFEST.COM 2018 Jeep Trackhawk 1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997 1971 Barracuda, 414ci, 6bbl Fitech, 727 1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
[Re: Mapandjlp]
#963918
04/04/11 11:56 PM
04/04/11 11:56 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
I was very happy with the mopar .450/.455 cam and similar gears in a 76 (ie, heavy) valiant...good idle, good vacuum, got into the 13's with 2.94 gears....not too shabby.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
[Re: 440newport]
#963921
04/05/11 07:51 PM
04/05/11 07:51 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
It lopes a little when cold, but sounds pretty mild when warmed up.
I have a Scott Brown 268/285 in my 9:1 360, it's the same way, sounds mean (for the street)when cold , then tame once it warms up. '68 Barracuda with 9.5" converter and 3.55 SG. When it ran 13.75, it was suffering from fuel starvation, undiagnosed at the time. Want to get it back to the track this spring, should be 13.5 or lower if I can hook.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
