Rockers for 440 build- stamped or roller? #963855
04/01/11 04:11 PM
04/01/11 04:11 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Opinions please!
I’m getting close to putting my engine back together for the ‘Bird. This is a 440 with a 4.15 stroker crank netting about 497 cubic inches, 10:1 compression and ported 906 heads. The cam is a custom ground hydraulic flat tappet from Hughes.
Here are my two paths I’m considering:
first is the lower cost option of the stamped MP “six pack” rocker arms and adjustable pushrods.
The second option would be the Hughes 1.5: roller rockers. The rollers would be considerably more of an investment (about $400 more) and I have no doubt that these would be the “better” option, but would they be worth the additional investment.
This is going to be a strong regularly driven street car with only a very occasional (if ever) pass down the strip. I’d like to save a few bucks if I can, but don’t want to cheap out on something that would be of significant benefit to my engine.
Thoughts?
Re: Rockers for 440 build- stamped or roller? [Re: 70Sbird] #963856
04/01/11 04:40 PM
04/01/11 04:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
$400 more for the rollers ? I just bought a set of smith bros adjustables and the KIT of stamped steel rockers from Mancini , $275 for the pushrods , $200 for the stamped steel kit and they didn't appear to be any better than the old std dutys I have and the side clearance between them ranged from .014 to .050 ...
If you need an adjustable valvetrain buy REAL adjustable rockers , you'll be happier in the long run
Re: Rockers for 440 build- stamped or roller? [Re: JohnRR] #963857
04/01/11 04:52 PM
04/01/11 04:52 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
John, thanks for the response.
The $400 is the difference beween the two options. The purchase price of the MP stamped set, adj. pushrods and rocker shafts is about $400. the adjustable roller kit with shafts, hold downs and pushrods is about $800. I'm just trying to decide if it's worth spending an extra $400 to get the roller rockers. I know they would be a better choice if money were no object, but I'm just not sure if It's justified for my application/build
Re: Rockers for 440 build- stamped or roller? [Re: 70Sbird] #963858
04/01/11 05:17 PM
04/01/11 05:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Will need to know the specs on the cam and valve springs before anyone can make a recommendation.
Why would you need adjustable pushrods? I ran a lunati voodoo 60303 cam with stock rockers and stock pushrods.
Re: Rockers for 440 build- stamped or roller? [Re: 70Sbird] #963859
04/01/11 06:55 PM
04/01/11 06:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
adj. push rods on my 440 and it has seen both street and strip time. never had a problem and i did it for the same reason - less $$$$
Re: Rockers for 440 build- stamped or roller? [Re: DaytonaTurbo] #963860
04/01/11 07:32 PM
04/01/11 07:32 PM
IN
ahy Offline
ahy  Offline
IN
Rule of thumb is HD stamped rockers are good for .5" lift. Perhaps a bit more on a moderate RPM stroker with moderate springs. It depends on the cam/spring combo.
Re: Rockers for 440 build- stamped or roller? [Re: ahy] #963861
04/01/11 07:47 PM
04/01/11 07:47 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
x3 ..... save your money and actually do yourself and the VALVE SPRINGS a favor by using the stamped-steel ones.....
The stamped steel ones to a better job "oiling"(cooling) the VS's ...
Re: Rockers for 440 build- stamped or roller? [Re: dOrk !] #963862
04/01/11 10:02 PM
04/01/11 10:02 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
thanks for the inputs,
I may have my answer based on some of your responses.
Cam specs are around (going from memory here as i am away from my buildsheet) .524/.558 lift and duration is 230 +/- @.050
I just looked up the valvesprings and they are 335# of pressure @ .550 lift
does that add any clarification?
Re: Rockers for 440 build- stamped or roller? [Re: DaytonaTurbo] #963863
04/01/11 10:06 PM
04/01/11 10:06 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
I am using adjustable pushrods since the block has been decked and the heads milled, the factory length has now changed slightly and I just want to be sure the lifters have the right preload, and are all even.
Re: Rockers for 440 build- stamped or roller? [Re: 70Sbird] #963864
04/01/11 10:13 PM
04/01/11 10:13 PM
IN
ahy Offline
ahy  Offline
IN
That cam/spring combo is really pushing it for stamped rockers. I'd go with stouter rockers. I'm partial to steel (Comp pro magnum or Crane ductile iron if available) but good aluminum would work also.
Re: Rockers for 440 build- stamped or roller? [Re: 70Sbird] #963865
04/01/11 10:30 PM
04/01/11 10:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would get a set of reliable adjustable iron units There was a nice looking set in the race parts for sale section.
Gus
64 Plymouth Savoy
Dana 60
Re: Rockers for 440 build- stamped or roller? [Re: fourgearsavoy] #963866
04/01/11 11:27 PM
04/01/11 11:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus
, rollers are over kill , especially the price , The comp pro magauns are 680 , you'll just need to buy pushrods .
Find a set of ductile units .
Re: Rockers for 440 build- stamped or roller? [Re: JohnRR] #963867
04/02/11 03:44 AM
04/02/11 03:44 AM
Manitoba, Canada
Manitoba, Canada
I would run stock rockers with that cam. Stock pushrods too if the heads/block haven't been milled that much. Like I said, I ran stock pushrods and rockers with a lunati voodoo 60303 cam which is a little smaller than the one you have. May make a difference that my rockers were off a 76 440, which some guy says the later 440's got the same HD rockers that mp sells now.
However I would sooner put that money towards a set of ductile rockers and new non-adjustable pushrods than spend it on adjustable pushrods for stock rockers. If you can reuse all your stock stuff, that's one thing, but I wouldn't invest into it.
