Restoring R 4218 Holley and need some help #963489
04/01/11 02:14 AM
04/01/11 02:14 AM
California
court9155 Offline OP
California
I have a few parts that I am wondering where to get replacements and I am also wondering if they are factory parts.
Ill post what I have right now, maybe someone can help.
This is the feed to the front bowl its R 4218. Is this ribbed nipple that you can pick up anywhere, an actual factory MOPAR part?
Ill post more pics and questions later as I continue to refurbish the carb.
Doin this just for the hell of it cuz Im kinda wheelchair, crutch bound right now.
Dan
67 charger
Re: Restoring R 4218 Holley and need some help [Re: court9155] #963490
04/01/11 02:40 AM
04/01/11 02:40 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
hose nipple not mopar .
fitting on left is correct .
Re: Restoring R 4218 Holley and need some help [Re: calrobb2000] #963491
04/01/11 02:42 AM
04/01/11 02:42 AM
California
California
hi
Thanks!
Any idea where to find a vacuum secondary diaphragm for a R 4218 holley 4160?
Dan
67 charger
Re: Restoring R 4218 Holley and need some help [Re: court9155] #963492
04/06/11 03:21 AM
04/06/11 03:21 AM
California
California
Well, made some progress on rebuilding the R 4218.
Figure Ill rebuild it and maybe someone can use it down the road since it seems to be unique to the application.
Still looking for secondary vacuum diaphragm.
Before:
He is 3!
Some after shots...learning a lot of the "secrets" of gettin it nice and clean.
May send it out for the dichromate finish as it has been removed. I guess there is a redneck way in a can to get this finish back lol
67 charger
