Torsion bar install "?" #963271
03/31/11 07:03 PM
03/31/11 07:03 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I just got done putting my torsion bars in. The drivers side was a real pain. Had to "vigorously tap" it into place. But it went in with just that amount of coaxing. The other side went right in. Did it with just my hands sliding it right into place (like it's supposed to do). It's been so long since I've done them I can't help but wonder if I've done something wrong on the drivers side. I can adjust both sides OK, but the pass side is easier. I'm thinking/hoping after I get it down on the ground and let it settle for a while all the planets will fall in line and things will be fine.
Any comments/suggestions? I guess I just need/want some reassurance.
Re: Torsion bar install "?" [Re: bigblock340power] #963272
03/31/11 07:46 PM
03/31/11 07:46 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I think you'll be fine. Production tolerances were "loose" at best back when these cars were built. Also some sag can occur on older cars.
Re: Torsion bar install "?" [Re: 469runner] #963273
03/31/11 09:17 PM
03/31/11 09:17 PM
BDW Offline
BDW  Offline
I had similiar experience with my install. It was just too much powder coating on the 1 side. As long as it's in, your good to go.
Re: Torsion bar install "?" [Re: BDW] #963274
04/01/11 09:06 AM
04/01/11 09:06 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Same here. Actually, exactly the same. The passenger side slid in, driver's side needed coaxing. No problem though. Drives straight and rides great!
Re: Torsion bar install "?" [Re: Mapandjlp] #963275
04/01/11 10:23 AM
04/01/11 10:23 AM
Elk Grove, Calif.
Elk Grove, Calif.
Thanks for the replies, I feel a little better about it.
I'm adjusting it, putting the wheels on, and letting it down on it's own feet today for the first time in quite some time.
Re: Torsion bar install "?" [Re: bigblock340power] #963276
04/01/11 10:59 AM
04/01/11 10:59 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
My experience has been that production tolerances were such that seldom were both bars indexed the same. This can result in having to pull one of the control arms down just to get the bar started especially when using rubber LCA bushings. This is also why usually one of the adjusters needs to be screwed in further than the other when setting ride height. If you're using poly LCA bushings I suggest driving the "T" bar all the way forward. That way once the bar is preloaded it will prevent the LCA from moving in a fore and/or aft direction, which can be a common occurrence with poly LCA bushings.
Re: Torsion bar install "?" [Re: 5spdcuda] #963277
04/01/11 11:29 AM
04/01/11 11:29 AM
Elk Grove, Calif.
Elk Grove, Calif.
I guess I should have explained a little further. I'm not using Poly bushings in the LCA's. However I am using fully adjustable tubular U"A"A's, and beefier adjustable strut rods. Another thing I did, was to tie the LCA assembly together with the weld in piece on the bottom of the LCA's. This should make the whole front end much more "adjustable" friendly, tighter, and make getting it to where I want it to be (instead of the factory) easier.
