340 Stroker cam Recommendations? #963105
03/31/11 04:05 PM
03/31/11 04:05 PM
Menomonie,wi
menomoniemopars Offline OP
Menomonie,wi
Ok the 340 is done for the challenger Now My brother is working on getting this other 340 built for his 72 charger,and Kinda looking for ideas for a cam etc, thinking solid roller? It will be a 416 with a eagle crank, eagle rods, J.E Pistons for a 10.1 comp with edelbrock heads, Probably just stock as their bought?, A Rpm Air gap Intake, or a single plane? 770 avenger? Headers,3:91 sure grip,auto with probably 10" 3500-3800 stall? Would still be steet driven, as well as taken to the local drag strip too. Welcome any and all Ideas!
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963106
04/01/11 11:36 PM
04/01/11 11:36 PM
Menomonie,wi
Menomonie,wi
Anyone got any ideas?
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963107
04/01/11 11:39 PM
04/01/11 11:39 PM
Renton Washington
Triple Threat Offline
Renton Washington
Stock Edelbrock Springs aren't good for much. If you want to run a solid roller you'll need to upgrade springs, locks and retainers.
What are your goals? ET? Power?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963108
04/02/11 12:02 AM
04/02/11 12:02 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I have a very similar setup to you using a 360/408. Out of the box edelbrock heads hyd flat tappet and 1.6 rockers. I went with a racer brown ssh-25 238/238 @ 0.50 and stock edelbrock springs. From what I can tell this brings ne right to the limit of the heads. I did have to do some clean up on the ports to smooth them out.
Sorry I can't comment on the roller.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: 340 Stroker cam Recommendations? [Re: Triple Threat] #963109
04/02/11 03:13 PM
04/02/11 03:13 PM
Menomonie,wi
Menomonie,wi
I think He is shooting for 475-500 hp?
E.T I don't know , I would say mid to low 12's to high 11's? Not Sure He hasn't been on the strip yet, Told Him its very easy to get hooked! .. I think his builder was thinking of a roller in the 240 range and 550 lift? Yea I would imagine his builder would know to change those Things out on the heads. Seems like a pretty stout solid for a stroker? I am A Pontiac man so I don't know much about Mopars as far as that stuff anyway.
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963110
01/08/12 02:16 AM
01/08/12 02:16 AM
Menomonie,wi
Menomonie,wi
Bringing this back up, Brother is wanting to order the heads etc, and now their thinking a solid flat cam instead of the roller, it will still use roller rockers tho... Any input on a cam for the 416? Thanks! I was thinking maybe the 557 mopar cam? Or the lunati 60442 cam?
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963111
01/08/12 10:56 AM
01/08/12 10:56 AM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I have the comp cam #20-231-4 in my 410" stroker with Hughes 1.6 roller rockers in an a-body. Also have a serious traction problem.
Re: 340 Stroker cam Recommendations? [Re: krw71ragtop] #963112
01/08/12 05:26 PM
01/08/12 05:26 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
We have a couple of strokers here....don't go less than 250* dur solid, it reacts like a big boy now !
Dan
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963113
01/08/12 06:25 PM
01/08/12 06:25 PM
Virginia
hokies1 Offline
hokies1  Offline
Virginia
I just got my 340 stroker back. Eagle stroker kit i used a Hyd roller muther thumper cam 235 249 @50 duration from comp cams. I got RHS heads with Hughs racing springs.Comp rollers and lifters.I do not have this in my duster yet. I would look at a HYD Roller cam if i was you the guys at comp will work with you.
Re: 340 Stroker cam Recommendations? [Re: hokies1] #963114
01/08/12 07:00 PM
01/08/12 07:00 PM
SoCal
Brian Hafliger Offline
SoCal
I recommend our 251 cam: 251-260@ .050, .580-.560 lift with 1.6 rockers, on a 108lca. With an unported eddy head it should make around 460-470Hp with 10.2:1 compression, 750 holley DP, rpm intake with a 1" open spacer and TTI or similar header.
With porting it can make 520+HP!
Brian
Brian Hafliger
Re: 340 Stroker cam Recommendations? [Re: Brian Hafliger] #963115
01/08/12 07:01 PM
01/08/12 07:01 PM
SoCal
SoCal
Brian
You'll need more spring than what the eddy heads come with...around 140lbs. closed and 340lbs. at .560 lift.
Brian Hafliger
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963116
01/08/12 07:06 PM
01/08/12 07:06 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: 340 Stroker cam Recommendations? [Re: Brian Hafliger] #963117
01/09/12 12:41 AM
01/09/12 12:41 AM
Menomonie,wi
Menomonie,wi
Brian
Where is that cam installed at then? That sounds like a pretty rowdy cam on a 108? He will still have power brakes, will need a booster? What size conv? part number for the springs and rockers?
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963118
01/09/12 03:47 AM
01/09/12 03:47 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Throw it all out the window with a stroker. It will likely have a noticeable idle with a 108º CL, but the fact is, a cam that's "big" in a 360 is "meh" in a 408. I ran the same cam in 2 different builds...one 360 and one 408. Cam was 254º @ .050" .525" solid on a 110ºLSA. The 360 had a real rumpy idle. The 408 sounded a lot more stock-ish...smoother idle, more vacuum...both cams installed straight-up. Fact is that the longer arm really eats up duration.
2 Demons...no, not my kids!
Re: 340 Stroker cam Recommendations? [Re: 4speeds4me] #963119
01/09/12 11:25 AM
01/09/12 11:25 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
For what it's worth.
I put my 416 together way before the craze was in full swing. My bud and I built ours with 308 swirl port heads (from a late '80s to early '90s wrecked trucks), worked/with 202/160's, porting/matching. A Mopar 508 cam, hydralic lifters, 1.6 roller rockers, Mopar M1 intake, Quick Fuel 950 carb. .30 over bore, 4.0 crank, 9.75 compression. Cars run low 11's to 10.80's all day long.
Good luck.
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963120
01/09/12 02:23 PM
01/09/12 02:23 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
That is an awesome cam with this combination, and its what I run on my 408/360 with a single plane intake and a Proform 850 carb. The all steel Cuda has been in the 10's with that set-up, and for what it is, it flies.
Re: 340 Stroker cam Recommendations? [Re: Dragula] #963121
01/11/12 09:47 AM
01/11/12 09:47 AM
Menomonie,wi
Menomonie,wi
Which Cam the 557 one? What single plane intake?
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963122
01/25/12 12:28 AM
01/25/12 12:28 AM
Menomonie,wi
Menomonie,wi
The engine builder suggested this cam, Comp Cams 20-616-5 Camshaft
I don't really think a oval racing cam is the way to go.. what do u guys think?
Re: 340 Stroker cam Recommendations? [Re: menomoniemopars] #963123
01/25/12 01:17 AM
01/25/12 01:17 AM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
post up the cam specs. most won't look it up to give an opinion.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 340 Stroker cam Recommendations? [Re: 73swinger] #963124
01/25/12 12:07 PM
01/25/12 12:07 PM
Menomonie,wi
Menomonie,wi
Thanks Chris!
3500 to 6500 RPM....Solid cam
adv 272 280, @ .050 242 250, .540 .556, 106° LSA 106 ICL
