Fuel Sender testing question #962843
03/31/11 03:47 AM
03/31/11 03:47 AM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
I hooked a trouble/test light up to the fuel sending lead (next to gas tank) on my 1967 Valiant and there was a light, but it slowly "pulsed" on and off. Is this normal?
I'm pretty sure the sending unit is shot, but I wanted make sure the pulsing light was normal. Maybe helped keep the gas gauge needle from bouncing all over the place?
Thanks ahead of time Mopar Dudes!
Re: Fuel Sender testing question [Re: rabid scott] #962844
03/31/11 08:15 AM
03/31/11 08:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes that is normal.If you connect a wire to it that is grounded and key on the gauge should peg to full.Just dont leave it on very long.I just hook it up then turn the key on.Rocky
Chrysler Firepower
Re: Fuel Sender testing question [Re: therocks] #962845
03/31/11 10:36 AM
03/31/11 10:36 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Also, before you pull the sender make sure it has a good
ground. Should have the strap from the fuel tube on the sender to
the fuel line on the body.
Re: Fuel Sender testing question [Re: demonH1B] #962846
03/31/11 04:36 PM
03/31/11 04:36 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
Thanks guys!!
