valve body install tips needed #962776
03/30/11 11:38 PM
03/30/11 11:38 PM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
i'm getting ready to install a crt full man rev pattern vb in my 727 with trans in car and i've never done any trans work other than changing pans and filters, but have plenty of commom sense and can figure most things out as i get into it. i was just wondering if there is any tips or tricks that i must do? my only concern is that if something is installed wrong that i may not notice. and wonder if i should adjust anything while in there. thanks for any info ive put this off for bout a year and im ready to try. getting spring fever i guess.
Re: valve body install tips needed [Re: jbcuda] #962777
03/30/11 11:44 PM
03/30/11 11:44 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I installed a reverse manual valve body in my transmission about a year ago. Don't worry - there's really not much to it. It's basically just a matter of unbolting the old one and installing the new one. BUT, you may want to take a picture of your shift linkage before tearing things down, just to be safe. Note: there may be a spring that you are NOT supposed to use in the new valve body. Read any included instructions.
Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: valve body install tips needed [Re: jbcuda] #962778
03/31/11 03:50 PM
03/31/11 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Place the shifter in Park and turn the rear wheels until you hear the park sprag click in, this will make the park rod easier to remove from the tail; don't turn the rear wheels while the VB is out.
While the pan is off adjust the rear band.
