Re: valve body install tips needed
[Re: jbcuda]
#962777
03/30/11 11:44 PM
03/30/11 11:44 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I installed a reverse manual valve body in my transmission about a year ago. Don't worry - there's really not much to it. It's basically just a matter of unbolting the old one and installing the new one. BUT, you may want to take a picture of your shift linkage before tearing things down, just to be safe. Note: there may be a spring that you are NOT supposed to use in the new valve body. Read any included instructions. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: jbcuda]
#962778
03/31/11 03:50 PM
03/31/11 03:50 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Place the shifter in Park and turn the rear wheels until you hear the park sprag click in, this will make the park rod easier to remove from the tail; don't turn the rear wheels while the VB is out.
While the pan is off adjust the rear band.
