Re: hughs main girdle
[Re: dirty magnum]
#962762
03/31/11 11:08 AM
03/31/11 11:08 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
has anyone used one , what did you think of the hardware? is it common to not have #5 studs go threw the girdle? thanks
BB or SB?
[Re: Fishmarket]
#962764
03/31/11 12:04 PM
03/31/11 12:04 PM
Guitar Jones
If its for a small block, don't bother... by the time I cleared for the rod bolts on my eagle h-beams, the girdle looked like a piece of swiss cheese.
Hmm, my Eagle H beams clear the girdle with a 4" arm.
[Re: Guitar Jones]
#962766
03/31/11 12:15 PM
03/31/11 12:15 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Not mine! My caps have a small flat machined into the top of them and the girdle resting right on it. Even if I used the shim method, it would have to have been 1/4" above the top of the cap to clear the rod bolts. We have different height caps I guess... mine is a 1972 340 block.
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Fishmarket]
#962767
03/31/11 12:24 PM
03/31/11 12:24 PM
Guitar Jones
That's odd, mine is a 74 360, maybe they are taller because the mains are bigger.
[Re: Guitar Jones]
#962768
03/31/11 02:54 PM
03/31/11 02:54 PM
dartman366
Mt. Vernon, Ohio
I machined the flat's on the cap's to ensure they are all the same height then made hardened washer's to shim the girdle to give .005 preload against the cap,plus I had the cap's pinned, haven't had it apart since so I cannot tell you if it fixed my slight cap walk, I know I had to slightly notch the girdle to get the needed clearance for the Eagle rod's and a 4" arm,,as far as the # 5 cap, I spotfaced the cap down so the nut and hardened washer would clear the oil pump on my small block,, also it is a 72 vintage 360 block.
[Re: bcrproducts]
#962772
03/31/11 08:48 PM
03/31/11 08:48 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Guys that setup for a BB is a waste of time and if it does not use a quality fastener what is the point??. Talk to Mike or Dale at Chenoweth Racing and ask them when the BCRproducts girdle will be back in production as they are close. They have caps now but I am not sure when the Caps and Girdle combo will be availabe.
Greg
i would think a used girdle could be used with the new caps if thay are not available.i have a cre 3/8 girdle on my other engine i no longer use.
[Re: dirty magnum]
#962775
04/01/11 04:20 AM
04/01/11 04:20 AM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Mine too. But my brass freeze plugs wasn't brass unless they have magic brass, that a magnet will pick up. Brian
