Re: Slant six's question-again
[Re: 446acuda]
#962440
03/30/11 02:21 PM
03/30/11 02:21 PM
Posts: 3,054 USA
b54406barrel
USA
crank will need some kind of bushing so that the smaller torque convertor hub will pilot correctly.
So, balance-wise they're all the same?
The TC hub is smaller diameter than the crank flange hole? Well, that's better than the other way around! Do I need to machine something or is that 'purchase-able' item?
[Re: b54406barrel]
#962441
03/30/11 04:23 PM
03/30/11 04:23 PM
RapidRobert
Not sure on the balance but I put a 70's 225 on an iirc 64 904 so I think they are all internal. It's best to use that bushing and www.wildcatauto.com used to sell them iirc $20 to your door. If not they'll www.slantsix.org know where to get one
[Re: RapidRobert]
#962442
03/30/11 05:15 PM
03/30/11 05:15 PM
Posts: 3,054 USA
b54406barrel
USA
Thank you! I tried that wildcat link & it's not 'valid' anymore. Is that the same place as this one? http://www.wildcatmopars.com/
I sent off an email to see if they had them & if not, it sounds like I better become a member of the slant6 forum!
[Re: b54406barrel]
#962443
03/30/11 05:27 PM
03/30/11 05:27 PM
Posts: 3,054 USA
b54406barrel
USA
Quick response from Wildcat! That is the same place & the bushing is $20 & it's on its way. Thanks for the help!
