440 Block / ID / Stamping #962319
03/30/11 10:04 AM
03/30/11 10:04 AM
CentralVA.
BBCoronet Offline OP
CentralVA.
Picked up a 440 engine that has VIN #s (I guess)stamped at the oil pan rail but nothing on the upper pad. What gives? Not sure what the engine came from but it was freshened up and has new flat top pistons.
Re: 440 Block / ID / Stamping [Re: BBCoronet] #962320
03/30/11 10:05 AM
03/30/11 10:05 AM
CentralVA.
CentralVA.
Upper pad................
Re: 440 Block / ID / Stamping [Re: BBCoronet] #962321
03/30/11 10:09 AM
03/30/11 10:09 AM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
If the vin starts with 1G1 it is a for 1971 St. Louis built car. Probably a B body. I do not believe any LP 440 engines were used at St. Louis. So it very well may be a 71 HP motor. If the VIN # is 1C1 it could be LP or HP. Not sure why there are no stampings on the top pad.
Re: 440 Block / ID / Stamping [Re: 70gtx440dana] #962322
03/30/11 11:22 AM
03/30/11 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's 1C from looking at the picture , the rods will tell him if it was an HP oor an LP if the engine is untouched from new.
As far as the top pad , whomever was supposed to stamp on the info didn't , I see an upside down A on there so it would appear the valley end rails have not been cut since it was originally built.
Re: 440 Block / ID / Stamping [Re: BBCoronet] #962323
03/30/11 11:51 AM
03/30/11 11:51 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like there's a couple of light stamped 7's up there.
Re: 440 Block / ID / Stamping [Re: buildanother] #962324
03/30/11 12:19 PM
03/30/11 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Looking at the pictures again you see blue paint under the orange , LP 440
Re: 440 Block / ID / Stamping [Re: JohnRR] #962325
03/30/11 01:00 PM
03/30/11 01:00 PM
CentralVA.
CentralVA.
Its not an HP engine for sure........ I looked at it again...... "A" & "3" are the only marks on the pad. When I first found it I thought it was a Warranty block. Does a warranty block have an assembly date stamped up top?
Re: 440 Block / ID / Stamping [Re: BBCoronet] #962326
03/30/11 01:04 PM
03/30/11 01:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It SHOULD , but it wouldn't likely have a VIN with very FACTORY LOOKING fonts and be that straight across.
Re: 440 Block / ID / Stamping [Re: JohnRR] #962327
03/30/11 01:16 PM
03/30/11 01:16 PM
CentralVA.
CentralVA.
The reason I asked about the build info is a guy on the WIW page has a 383 engine with blank pads top and bottom. Long ago I had a 440 block that was completely blank but I believe it was a warranty block- Not an engine.
Re: 440 Block / ID / Stamping [Re: BBCoronet] #962328
03/30/11 01:24 PM
03/30/11 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I saw that one , that block was more than likely decked and the info removed in the process ..
Just an FYI ... ANYONE could saunter into a chrsyler/plymouhth/dodge dealer and just BUY a brand new block if they chose to, in that case there would be little to nothing stamped ANYWHERE.
Warranty BS is just that in most cases ... BS ...
