Re: Clutch Adjustment
[Re: dart4forte]
#962244
03/30/11 09:17 AM
03/30/11 09:17 AM
Posts: 1,374 North Central Indiana
C-Tech
Basically you do not want the fork pressing against the throw out bearing when the clutch pedal is released. You should have about 1 to 1.5 inched of travel (at the pedal) as you push the pedal down before the fork touches the throw out bearing. As the clutch wears the throw out bearing moves closer to the fork and you will have to add free play. a fork that touches the throw out bearing all the time will #1 cause the throw out bearing to rotate all the time which wears it out and #2 can cause the clutch to slip. I hope that makes sense
Kevin
[Re: dart4forte]
#962246
03/30/11 03:09 PM
03/30/11 03:09 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory says to adjust the pushrod gap at the throwout fork at 5/32".
[Re: dart4forte]
#962248
03/30/11 08:34 PM
03/30/11 08:34 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
I've concluded that adjustment is not the issue. I either have a bad throwout bearing, pilot bushing or both. I'm also not rulling out that the bell housing is misaligned.
What is the symptom of the 'issue'???
