SB stroker intake recommendation... other than Perf RPM #962225
03/30/11 12:08 AM
03/30/11 12:08 AM
Space Station #5
471Magnum Offline OP
Space Station #5
My new stroker short block is coming together. Budget constraints are limiting the initial project to just the short block. Stock top end is going on the motor for the first phase.
This hasn't kept me from planning for phase 2 though. If/when the budget permits, I'll spring for some slightly worked RHS heads, and poke in the Comp XE275HL I've got on the shelf.
Once I hit that stage, I also really need to ditch the stock T-quad intake. Due to my Air Grabber, I'm limited to something that has a near stock height, which rules out the favorite Performer RPM. Just because I'm a glutton for punishment, I might also try to stick with a Thermoquad.
What options are out there that will fit? Strip Dominator? Torker 2? LD340?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: SB stroker intake recommendation... other than Perf RPM [Re: 471Magnum] #962226
03/30/11 08:15 AM
03/30/11 08:15 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what's keeping you from putting the cam in now?
I'd look at the LD340 modded to fit the t-quad...the air gap really isn't that tall, it's the same height as a performer RPM, which I think is about the same height as the LD340...
the mopar M1 single plane will also work with a spread bore, but IIRC is taller...
there's the wieand action plus and stealth...I don't think they're quite as tall as the edelbrocks...
the torker II IIRC is shorter than the RPM/air gap, I've never really been a fan of low rise single planes, personally.
with that cam and in a street car I'd probably stick with a dual plane....
2017 Grand Cherokee Overland
Re: SB stroker intake recommendation... other than Perf RPM [Re: patrick] #962227
03/30/11 08:42 AM
03/30/11 08:42 AM
Space Station #5
Space Station #5
The XE275HL has too much lift (.525")for the stock springs. Required springs would probably require spring seat mod. Too much trouble at this stage.
Just to clarify, the intake change won't occur until I do the cam and head swap.
RPM and RPM Airgap are about 3/4" taller than the Performer. Neither will hold a T-quad.
Torker II is another 1/2" taller still, so it's definitely out of the question.
-Jim
Re: SB stroker intake recommendation... other than Perf RPM [Re: 471Magnum] #962228
03/30/11 09:01 AM
03/30/11 09:01 AM
scratchnfotraction Offline
holley street dominator is a single low rise amd will take a spredbore
the weiand action plus is another good choise,IIRC is about the same hieght as a stock intake
the comp 901-16 spring is a single with damper,drops on with stock hardware and stock valve seals
they work great with my voodoo roller cam turning to 6200 rpms with no valve float
Re: SB stroker intake recommendation... other than Perf RPM [Re: 471Magnum] #962229
03/30/11 11:01 AM
03/30/11 11:01 AM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
If the new stroker is for your 72 rr, I would recommend the Weiand 8007 action-plus. It's a great intake AND fits a thermoquad if you want a factory appearance. Only negitive is: the action-plus does not have the factory style mounting boss for the coil. I used a bracket I found and mounted it similar to the 340 6-packs.
Re: SB stroker intake recommendation... other than Perf RPM [Re: MoparDan] #962230
03/30/11 11:21 AM
03/30/11 11:21 AM
Space Station #5
Space Station #5
Regarding the Weiand intakes, looks like the only difference between the Stealth and the Action-Plus is the latter is machined to handle both a square and spread bore. They look to be the same casting. Am I seeing this correct?
Stealth
Action Plus
Both being dual planes, are they going to offer much improvement over stock, or do they just amount to an expensive weight reduction? Also, even though the 8007 is machined for a T-quad, it does not have a choke well, so I’d have to somehow install an electric choke. Might have to scavenge some parts off a later T-quad.
What’s the difference between the Holley Strip Dominator, and the Street Dominator? Can’t find much info on either.
With the extra torque inherent to the stroker motor, I’m not too concerned with low-end torque loss normally associated with a single plane. In fact, I have my doubts that any dual plane other than the RPM can support the flow potential of the RHS heads. This is by no means a max effort motor, but I don’t want to leave 50 hp on the table just because I don’t have a decent intake.
Yes, this motor is going in my 72 RR.
Regarding the cam/springs, CC recommends a dual spring with this cam. That's not to say I couldn't get by with a single/damper combo. Just need to make sure I have plenty of valve clearance and keep the revs down. I'll evaluated the cam situation closer once I tear the current motor apart and I know for sure what I've got to work with.
-Jim
Re: SB stroker intake recommendation... other than Perf RPM [Re: 471Magnum] #962231
03/30/11 12:24 PM
03/30/11 12:24 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for $95, get some hughes #1110 springs. they'll handle the cam with no spring seat mods, and can reuse stock (non rotator) retainers.
comp 901's don't have enough compression before coil bind for an XE275HL...
Re: SB stroker intake recommendation... other than Perf RPM [Re: patrick] #962232
03/30/11 01:10 PM
03/30/11 01:10 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Th Weiand Stealth is a good manifold. I have never seen an Action Plus, but there must be some difference since the RPM range is different. I liked my Stealth until I was serious about racing and then I went to single plane. I don't recommend an single plane for the street unless you plan on using 4.30's or 4.56 gears. A dual plane has a world more response. I has a strip dominator with my W2 heads and had to change cam and intake to make it perform wit 3.23 gears.
Re: SB stroker intake recommendation... other than Perf RPM [Re: babarracuda] #962233
03/30/11 01:40 PM
03/30/11 01:40 PM
Space Station #5
Space Station #5
I have actually been contemplating that spring .
The Weiand Stealth is a good manifold. I have never seen an Action Plus, but there must be some difference since the RPM range is different.
Pictures would sure seem to indicate otherwise.
-Jim
Re: SB stroker intake recommendation... other than Perf RPM [Re: babarracuda] #962234
03/30/11 05:47 PM
03/30/11 05:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I thought the action plus was 318 sized ports, but the pics look otherwise...never seen both side by side...
Re: SB stroker intake recommendation... other than Perf RPM [Re: patrick] #962235
03/30/11 08:24 PM
03/30/11 08:24 PM
Space Station #5
Space Station #5
Here is the Weiand catalog page.
http://www.holley.com/WeiandCatalog/Catalog.asp?pageNumber=32
I see nothing to indicate there is any difference in the castings. Same port size. Same dimensions.
Re: SB stroker intake recommendation... other than Perf RPM [Re: 471Magnum] #962236
03/30/11 10:20 PM
03/30/11 10:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
With stock heads you'll probably have to have the guides cut for that much lift.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB stroker intake recommendation... other than Perf RPM [Re: Triple Threat] #962237
03/31/11 12:18 AM
03/31/11 12:18 AM
Space Station #5
Space Station #5
Probably. Won't know for sure until I take it apart.
I'll re-use the current bump stick and leave the new one on the shelf if it that turns out to be the case. I really don't even want to drop a $100 on a set of springs for phase 1.
Finishing up the machine work on the stroker now, so it won't be long until I tear out the 340 and have a look.
-Jim
