AAR fenders #962191
03/29/11 11:51 PM
03/29/11 11:51 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I recently heard that AAR fenders are wider than regular Cuda fenders. THe person that told me said it was due to the larger tires, they weren't sure whether it was wider side to side or if it had to do with the wheel opening. I has been a long time since I researched AAR specifics, but I cant remember ever hearing that or anything like that before. DOes anyone have any info on this or even any myth related to this that might exist.
Thanks in advance, Kevin
Careful, your character's showing!
Re: AAR fenders [Re: mopar346] #962192
03/30/11 09:01 AM
03/30/11 09:01 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
The wheel opening is the same. There have been alot of discussions if the lips were rolled in.
The tire size in the from were E60-15 which are smaller than the Hemi tire size.
performancecarrestorations.com
Re: AAR fenders [Re: mopar346] #962193
03/30/11 09:32 AM
03/30/11 09:32 AM
cataclysm80 Offline
cataclysm80  Offline
Originaly there were plans to use special fenders with the AAR & T/A, which are mentioned in some chrysler literature, but it never materialized. The AAR & T/A fenders are the same as regular fenders.
I have heard about the rolled wheel lip (Hemi) fenders being installed on some AAR & T/A, sometimes only on one side of the car, but it is rare and unnecessary. Probably some confusion at the factory about the special fenders that were never made. The rolled lip fenders are the same as regular fenders, except that the top portion of the wheel lip (where the wheel well trim attaches) has been rolled/bent upward to provide extra clearance for the big tires that were only available on the Hemi cars.
Tav
Re: AAR fenders [Re: cataclysm80] #962194
03/30/11 03:11 PM
03/30/11 03:11 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks guys, any other info?
Re: AAR fenders [Re: mopar346] #962195
03/31/11 07:10 AM
03/31/11 07:10 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
In 1970 I owned an AAR. I had a fender-bender and decided to replace the left front fender. The original fender had the lip rolled under at the top. The replacement did not.
Re: AAR fenders [Re: TooMany62s] #962196
03/31/11 09:33 AM
03/31/11 09:33 AM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
Pretty sure the wheel size was the determining factor. If the car was ordered with 15X7 wheels you received the rolled fenders. There may have been an exception with the TA/AAR cars due to the smaller front tire.
I know they are often referred to as 'hemi' fenders but you could order the 15 X 7 wheel on other engined cars and get the fenders. I have seen them on 440-6 cars as well.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: AAR fenders [Re: BS27R1B] #962197
03/31/11 09:42 AM
03/31/11 09:42 AM
cataclysm80 Offline
cataclysm80  Offline
no no, Not Wheel size, Tire size. Lots of cars came with 15 inch wheels and didn't get special fenders. Hemi cars had F-60 Tires.
Here's a pic of a Hemi fender.
The part # is listed as a 70-71 Challenger with F-60/15 tire.
One of the guys from creative industries that did the fender modifications on the early cars was here on moparts talking about this recently.
Tav
Re: AAR fenders [Re: cataclysm80] #962198
03/31/11 09:51 AM
03/31/11 09:51 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
One of the guys from creative industries that did the fender modifications was here on moparts talking about this recently.
Tav
Not to discount your fender picture here but that appears to be on the extreme side of a regular rolled fender.
logan426
Re: AAR fenders [Re: MLR426] #962199
03/31/11 09:57 AM
03/31/11 09:57 AM
cataclysm80 Offline
cataclysm80  Offline
I see what you're saying. I think it's the angle of the photo, and because you can't see the bottom of the fender for reference in that pic. Here's another pic of the same fender.
Tav
Re: AAR fenders [Re: cataclysm80] #962200
03/31/11 02:17 PM
03/31/11 02:17 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Tav
wow, now that looks totally different than the first photo.
logan426
Re: AAR fenders [Re: MLR426] #962201
03/31/11 08:26 PM
03/31/11 08:26 PM
mopar346 Offline OP
mopar346  Offline OP
Interesting, I will check my fenders when I get home, but I am sure I would have noticed that by now.
Re: AAR fenders [Re: cataclysm80] #962202
03/31/11 09:48 PM
03/31/11 09:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That does not appear to be a factory installed fender, at least not to me.
Re: AAR fenders [Re: cataclysm80] #962203
03/31/11 11:18 PM
03/31/11 11:18 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
OK I guess that is what I was implying as I am not familiar with all the tire options on the e-bodies.
What other 15" front tires were available on the e-bodies aside from the E and F 70 X 15?
Was there another 15" wheel available on the 70 E-bodies other than the 15X7? I always thought the standard wheel on the E-bodies was 14X5, with 14 X6 and 15X7 the optional wheel sizes.
Jim Steinman
Re: AAR fenders [Re: BS27R1B] #962204
04/01/11 11:47 AM
04/01/11 11:47 AM
cataclysm80 Offline
cataclysm80  Offline
No Problem, you're pretty close. Here's the tire application page out of the 1970 Dodge Division Code Guide for Challengers. (Barry, do you have this resource? Mine is a xerox copy. Let me know if you need a copy.) It shows the F60 tire as only being available on the Hemi.
Note: the hand written "OPT" in the 225 column was already there when I got this copy and I haven't verified it's accuracy yet. The booklet is dated Oct 1969, and as you all know, sometimes things change during production.
Tav
Re: AAR fenders [Re: Alaskan_TA] #962205
04/01/11 12:03 PM
04/01/11 12:03 PM
cataclysm80 Offline
cataclysm80  Offline
Hi Barry, always good to hear from you. It's not my fender, It belongs to another moparts member, and I only have these two pictures of it, so I'm unable to verify its authenticity. It's deffinately a used Challenger fender, but beyond that . It's supposed to be representative of the later hemi fenders as indicated by the special inner fender brace, rolled wheel lip, and part #. It took awhile for the factory to come up with these special fenders, but they're vendor supplied and should all look pretty much the same. The early hemi fenders were done by hand on the car at creative industries, so they will exhibit variations. The creative industries hemi fenders have the inner brace removed because it was attached to the wheel lip they were trying to roll.
I'm curious what makes you suspect that it may not be a factory installed fender? Is it the lack of undercoating? You could be right, this might be a replacement hemi fender purchased over the counter.
Tav
Re: AAR fenders [Re: cataclysm80] #962206
04/01/11 01:44 PM
04/01/11 01:44 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
The later Hemi fenders were stamped,not rolled at the stamping plant.There were no replacement Hemi fenders until the stamped fender was ready about March-April of 70 as I have stated before.Creative never did extra fenders for service.
Two troubling issues with the fender pictured
1. They bent the fender in the wrong place.
2. Should not have a strap.
Re: AAR fenders [Re: mike s] #962207
04/01/11 06:57 PM
04/01/11 06:57 PM
cataclysm80 Offline
cataclysm80  Offline
I agree with that completely, and never meant to imply otherwise. After Barry's comment, I was thinking that it was perhaps one of these service fenders. It definately isn't a Creative Industries fender, as those were modified standard fenders and wouldn't have the hemi fender specific part # on it.
So the later Hemi fenders did not have a rolled wheel lip? Was their wheel lip stamped flat (folded over similar to the creative fenders), or do they not have a wheel lip at all?
So you're saying that the later hemi fenders also didn't have that inner fender brace?
Thank You all for bringing this to my attention Logan426, Barry, & Mike S. That's enough to convince me. It sounds like that fender I posted pics of is a fake. I'm not a hemi fender expert, I just pay attention when people like Mike S talk. He knows way more about hemi fenders than anyone I can think of. Those two pictures of that fender came from a long ago moparts thread about hemi fenders. No one in that thread, or the other recent thread I posted them in indicated any suspicion that the fender was a fake. I've seen several pictures of the creative industries fenders, but these are the only pictures I've seen claiming to be the later hemi fender. If someone has a pic of the later hemi fender, would they please post it so that I can see the differences? If those pics I posted above are a faked fender, I'll delete the files so that the misinformation doesn't spread.
Tav
Note to the original poster: This unfortunate fender photo incedent doesn't change what has already been said about AAR fenders, and which cars should have received Hemi fenders.
Re: AAR fenders [Re: cataclysm80] #962208
04/01/11 09:52 PM
04/01/11 09:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I would not call it a fake, it is obviously a fender.
It just does not appear to be a factory installed fender. Lack of sound deadener, the part number for the NOS system & the cars were painted with the valance on, then it was removed & re-installed after the bumpers were put on.
So, it looks like a used replacement fender to me. Rolling them with baseball bats was also a common owner trick back then for fat aftermarket tires.
I have still not seen any proof of rolled fenders from the factory.
If someone has some, I am sure that we would all love to see it?
Barry
Re: AAR fenders [Re: Alaskan_TA] #962209
04/02/11 02:43 AM
04/02/11 02:43 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Let me be clear about this only the Challengers had the brace and had it removed.As were the wheel lip mouldings.No brace on a Hemi Cuda
The reason as stated for modifying the fenders was correct.Tire size nothing else.
The stamped fenders (cars with a second tag stating Hemi fender) were folded back but also had a bit of the material removed.(the area where the brace joined the fender was removed IIRC).The overall area that was modified was slightly smaller than the hand modified fenders.The overall look is more squarish than the Creative mods.
There is a part number that I have yet to receive that was issued for the stamped fenders.(still trying to get it)
So far I have not been able to pinpoint the production dates on the Hemi E-bodies.It would be a great help to see how many cars were built after the stamped fender was ready.
I took a second look at the first fender picture the area modified is at least 3 times longer than the correct mods.
Leave the gun.......take the Cannoli's....Mike
Re: AAR fenders [Re: mike s] #962210
04/02/11 04:43 AM
04/02/11 04:43 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The aar cuda I'm working on now doesn't have any rolling in the lip. One was a factory replacement fender, the other was the original to the car.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
