What waterpump with cam driven fuel pump #961805
03/29/11 05:42 PM
03/29/11 05:42 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
So I was told today that I won't be able to run my stock style aluminum waterpump on my RB 512 ci since I am converting to mechanical injection on alcohol with a cam driven pump What are you guys running for a waterpump if you are running a cam driven pump and any pictures of your cooling setup would really help me as this stuff is all new to me
Derrick
Re: What waterpump with cam driven fuel pump [Re: Hyper Henry] #961806
03/29/11 06:43 PM
03/29/11 06:43 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Inline pump on the rad hose and a custom feed and return manifold at the block.
Re: What waterpump with cam driven fuel pump [Re: Hyper Henry] #961807
03/30/11 12:42 AM
03/30/11 12:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
So I was told today that I won't be able to run my stock style aluminum waterpump on my RB 512 ci since I am converting to mechanical injection on alcohol with a cam driven pump  What are you guys running for a waterpump if you are running a cam driven pump and any pictures of your cooling setup would really help me as this stuff is all new to me    Derrick
There is a viable alternative to the cam driven pump, that is cog belt driven pmump off of the crankshaft I plumb one of them on a Hilborn injected alcohol 426 Hemi years ago Worked good, lasted a long time I think most of the Rons toilet injection systems use the belt driven pumps
Re: What waterpump with cam driven fuel pump [Re: Hyper Henry] #961808
03/30/11 01:01 AM
03/30/11 01:01 AM
AndyF Offline
AndyF  Offline
Use water manifolds. These are a standard product that I make. Part number is AR245.
