Re: Max Power Turbo 440 Block
[Re: SILVER67]
#961523
03/29/11 11:12 AM
03/29/11 11:12 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
400 block would be better IMO. Mine has Indy alum. caps, hughes girdle, alum. rods. I think rpm, and detonation are what kill blocks not the power. (I'm sure they have a limit but I have not reached it yet) I have made hundreds of passes with this block with 300hp of nitrous and 30-35 passes with 15-16 lbs with turbo, and have just a few weeks ago made about 10 dyno pulls with 25 lbs with my 101mm.
One day I will have something cool here.
[Re: SILVER67]
#961525
03/30/11 02:04 PM
03/30/11 02:04 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You can make LOTS of power with a stock 440 block on three conditions: 1) keep rpm low 2) avoid detonation at all cost 3) take care of the equipment
[Re: SILVER67]
#961529
03/31/11 04:32 PM
03/31/11 04:32 PM
feets
Senior Management
Senior Management
Irving, TX
The larger turbo will make more power and be more detonation resistant. The small turbo will be out of it's efficiency range and will heat the air excessively. The intercooler will only cool so much. A larger turbo with the impeller to handle that size engine won't make as much heat.
[Re: SILVER67]
#961531
04/01/11 01:19 PM
04/01/11 01:19 PM
feets
Senior Management
Senior Management
Irving, TX
Majestic is local to me. I've been dealing with those guys since 2001. They have always treated me well.
9.5 is getting a little high for a turbo car. It can be done but I prefer to stay between 8.5 and 9.
