Wiring in late 70's 100 amp alternator into 69 Chrysler
#961347
03/28/11 11:57 PM
03/28/11 11:57 PM
Posts: 395 Knoxville, TN, USA
mantonas
Knoxville, TN, USA
I have a bone stock 400 engine from a 78 Charger that I want to drop into my 69 Chrysler until I rebuild the original engine. It has one of those giant 100 amp alternators on it. It has four wires: a giant ground that attaches to the intake manifold, an equally giant wire that is cut off which I think is the battery wire, and two smaller wires that were also cut off that were on a plug that attaches to twin blade connectors on the alternator. How would I wire this into my electrical system? I already bypassed my ammeter following the instructions from MAD electrical (here's the link: http://www.madelectrical.com/electricaltech/amp-gauges.shtml). So I guess I could run the giant battery wire to the post on the starter relay. I don't know what to do with the other two wires. I searched the tech archives and didn't come up with anything, and I will dive into the wiring diagrams if I have to, but I just wanted to see if anybody else had already done this. Also, if it helps, the ignition is already converted to electronic, and I replaced the voltage regulator with a transistorized stock replacement, no rewiring necessary.
69 Chrysler 300 Convertible
77 Chrysler New Yorker Brougham 2-dr
03 Jeep Grand Cherokee Limited
Re: Wiring in late 70's 100 amp alternator into 69 Chrysler
[Re: ahy]
#961349
03/29/11 12:21 AM
03/29/11 12:21 AM
Posts: 7,664 IN
ahy
IN
[Re: ahy]
#961350
03/29/11 10:12 AM
03/29/11 10:12 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
will need to consider a higher upper radiator hose for belts clearence
[Re: NachoRT74]
#961351
03/29/11 10:33 AM
03/29/11 10:33 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I think he addressed that ...
On my car (70 challenger) I moved the receiver/dryer back an inch or so to clear the alternator. I also had to extend the cooling neck about 1 1/2" to get the stock style top radiator hose to clear the belts to a Sanden air conditioning compressor.
[Re: JohnRR]
#961352
03/29/11 02:07 PM
03/29/11 02:07 PM
NachoRT74
Valencia, España
yeap, sorry, noticed that later LOL
[Re: NachoRT74]
#961353
03/29/11 11:20 PM
03/29/11 11:20 PM
mantonas
Knoxville, TN, USA
This is exactly the information I was looking for. I hadn't even thought about the upper radiator hose clearing the A/C belt. I will have to check that.
By the way, how did you extend the water neck so you could keep using the same upper radiator hose?
[Re: RapidRobert]
#961356
03/30/11 11:28 PM
03/30/11 11:28 PM
mantonas
Knoxville, TN, USA
How about the lower radiator hose? I couldn't tell from the photo if you had retained the post-1973 water pump housing with the lower radiator hose connection on the passenger side. This wouldn't work with the stock radiator in your 70 Challenger. What did you do?
My radiator is shot, so I'm toying with buying one of those aluminum radiators with the lower hose connection on the passenger side. Otherwise I have to replace the water pump housing, but my motor came with a power steering pump which I would like to use, and I can't tell by looking at it if the lower radiator hose exiting on the driver's side would interfere with it.
[Re: mantonas]
#961357
03/30/11 11:31 PM
03/30/11 11:31 PM
NachoRT74
Valencia, España
alt bracketing has nothing to do with water pump housing, so I don't think he changed that... if he did it is just because he didn't have one or damaged the original one.
[Re: ahy]
#961360
03/31/11 07:29 AM
03/31/11 07:29 AM
mantonas
Knoxville, TN, USA
Yes, my original engine is a 440.
You are right to put the word "temporary" in quotes considering how much work I might end up doing to make it fit. I really wanted to do nothing to it and just drop it in. The engine I got is really complete. The guy I bought if from just disconnected or cut all the wires and hoses and yanked it out. It still has oil in it! And it's still attached to the transmission.
Since my radiator is shot, I have an opportunity to buy one that will fit the 400 engine, but that will lock me in to a non-stock look for the future. I have to decide how much I care about that (considering what I want to do to the original engine someday when I rebuild it, I don't think I care very much at all!). The other option is to buy some of those rigid tubes from that place that RapidRobert linked to and make a lower radiator hose that will reach from the passenger side on the engine to the driver's side on the radiator.
This is not the least of my worries. I might have to change the exhaust manifolds - not looking forward to that!
