Need help authenticating a shaker bubble #961293
03/28/11 10:48 PM
03/28/11 10:48 PM
Illinois
P
plmrag1 Offline OP
plmrag1  Offline OP
P
Illinois
There is a part number but it is in the wrong place compared to my original one. The underneath does not seem the same as my original one. He is saying it is NOS and it has been painted non of the bosses for the grill"s have been drilled.
Re: Need help authenticating a shaker bubble [Re: plmrag1] #961294
03/28/11 10:49 PM
03/28/11 10:49 PM
Illinois
P
plmrag1 Offline OP
plmrag1  Offline OP
P
Illinois
second pic
Re: Need help authenticating a shaker bubble [Re: plmrag1] #961295
03/28/11 11:29 PM
03/28/11 11:29 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I can't make out a thing with those small pics...And the magnifying glass does'nt seem to work on a computor screen...
Re: Need help authenticating a shaker bubble [Re: screamindriver] #961296
03/28/11 11:31 PM
03/28/11 11:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the opening for the grilles do not look right to me..
Re: Need help authenticating a shaker bubble [Re: AARCONV] #961297
03/28/11 11:34 PM
03/28/11 11:34 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
the pics are 1.75", opening the attachments makes them 1.50", really too small to see.
Re: Need help authenticating a shaker bubble [Re: Golden-Arm] #961298
03/29/11 12:11 AM
03/29/11 12:11 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Definately not a real bubble.
Re: Need help authenticating a shaker bubble [Re: mccannix] #961299
03/29/11 12:30 AM
03/29/11 12:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, definately a reproduction.
Re: Need help authenticating a shaker bubble [Re: plmrag1] #961300
03/29/11 08:40 AM
03/29/11 08:40 AM
Illinois
P
plmrag1 Offline OP
plmrag1  Offline OP
P
Illinois
It does have the chrysler pentstar also and both part numbers.
The front does not look right to me....The ridge by the grill opening.
Re: Need help authenticating a shaker bubble [Re: plmrag1] #961301
03/29/11 09:01 AM
03/29/11 09:01 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Most of the repros have the part number, vendor code and the pentastar but that is no guarantee it is real.
As other have said here it is definately a reproduction and not even a good one.
You state the bosses are not drilled.....bear in mind NOS scoops came with all bosses drilled.
Re: Need help authenticating a shaker bubble [Re: ScottSmith_Harms] #961302
03/29/11 10:47 PM
03/29/11 10:47 PM
Illinois
P
plmrag1 Offline OP
plmrag1  Offline OP
P
Illinois
Thanks Scott I thought it was but just want to make sure before I send it back.
Jerry Piaskowy
Re: Need help authenticating a shaker bubble [Re: plmrag1] #961303
03/29/11 10:56 PM
03/29/11 10:56 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Real Oem
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961304
03/29/11 10:57 PM
03/29/11 10:57 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
bottom
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961305
03/29/11 10:58 PM
03/29/11 10:58 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Cleaned
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961306
03/29/11 11:00 PM
03/29/11 11:00 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
pn
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961307
03/29/11 11:02 PM
03/29/11 11:02 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
repop
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961308
03/29/11 11:02 PM
03/29/11 11:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The bubbles with the angular front openings (like the first one posted in this thread) are that way because someone is molding them in fiberglass off of an original then trimming the openings with angular straight cuts without removing enough material and shaping the openings with the gentil and continuous curved opening shape that the originals had (as shown in R/T's 1st example above my post). Notice how thick his second example is around the opening? The originals taper to a much thinner/sharper edge at the opening as opposed to a thick straight cut. I'd guess his second example is an AAR Fiberglass reproduction, not exact but one of the closer reproductions on the market.
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961309
03/29/11 11:03 PM
03/29/11 11:03 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
repop bottom
Re: Need help authenticating a shaker bubble [Re: quick77rt ] #961310
03/29/11 11:11 PM
03/29/11 11:11 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Dont know where the repop just came from really, pretty good but twice the weight. One could probably grind and make it look more oem as mentioned, but this is just for a driver so not worth it.
