Engine builders...Now what?
#961205
03/28/11 08:27 PM
03/28/11 08:27 PM
Posts: 634 USA
Slider
super gas
super gas
USA
Hi, all! I bought a project 68 Barracuda with the engine out of it. The engine (318) came with it, just separate, and is currently residing on my garage floor. The previous owner said he removed it because it blew a rear seal, and he wanted to freshen it up (rebuild it) while it was out. The engine looks to be basically back together except for the intake and valve covers (which also came with it, just not installed). My question is, how much do I trust what was done? Granted, it is 'just' a 318, and this isn't what I would consider a rare car, but it _is_ the original engine. Do I just drop it in, and hope for the best? Is there a break-in procedure that I should follow, just in case? Should I have someone tear it apart and go through it? (And, does nybody have a ballpark on what it might cost?) I am open to suggestions.
Re: Engine builders...Now what?
[Re: wicked]
#961207
03/28/11 09:28 PM
03/28/11 09:28 PM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
I have learned not to trust anything, tear it down and inspect
[Re: BigTerry]
#961208
03/28/11 09:35 PM
03/28/11 09:35 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Better to do it now while it's out.
[Re: MoparforLife]
#961210
03/28/11 09:48 PM
03/28/11 09:48 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
How much background do you have in engines? If there are problems will you recognize them? If it were me for the price of a gasket kit I'd tear it down & have a look but if you aren't gonna have any more skill than the previous person working on it.....
[Re: MoparforLife]
#961211
03/28/11 09:52 PM
03/28/11 09:52 PM
vdriver
Leucadia, Ca.
Years ago I bought an old boat with a "rebuilt" 413 in it. Didn't care if it was rebuilt or not; I just wanted the old tub for a bunch of hardware it had on it - steering stuff, v-drive unit, crank, etc. Got the whole thing dirt cheap. Just for grins I took it out for a spin and it ran horrible. Big deal; didn't buy it for the 413 anyway. When it came time to strip it I found hand a couple of hand-tight head bolts, and the flywheel had 3 bolts holding it on - one of which was halfway backed out with stripped threads. I've never trusted anybody's "rebuild" ever since.
[Re: 1_WILD_RT]
#961213
03/28/11 10:15 PM
03/28/11 10:15 PM
Challenger 1
Cincinnati, Ohio
Get to know someone who may do some motor wrenching. Learn some stuff. A factory service manuel for your year 318 will instruct you 99.5% and the rest is right here.
YOU GOT TO HAVE ONE TO REBUILD YOUR MOTOR.
You definitly should take it apart before running it. You should do it, it will be very rewarding and that's what these old cars are about.
I'm thinking you may find someone that might dis assemble and re assemble it for around $500-750 labor plus gaskets or parts. If the gaskets were put on right, a lot of them will be reusable too. You should do it.
[Re: Challenger 1]
#961214
03/28/11 10:31 PM
03/28/11 10:31 PM
Posts: 892 USA
krw71ragtop
USA
Pull it apart just to be on the safe side. It will be much cheaper now compared to what it will cost if you install it without checking it and it blows up.
[Re: Slider]
#961217
03/28/11 11:55 PM
03/28/11 11:55 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yeah, that's what I was thinking. I have NO background in assembly. I already have the factory service manual, though, and am a stickler for research/details. I might just give tearing it down a shot! What's the worst that could happen? LOL!
Seriously, though. If it does grenade, I will have learned something, AND it wouldn't be a $1,000 motor... Hmmm...
Good answer, some might take my first comment as somewhat a$$hole like, I didn't mean it that way & apparently you didn't take it that way.. As was mentioned you've got a manual, you've got Moparts, you live in an area where there are likely other members who might offer a hand.. The engine is already a question mark... Take it apart... In everything inside iis right it cost you a gasket set, if you find & correct a problem your way ahead... The only way to learn is to get dirty...
[Re: Slider]
#961222
03/30/11 08:32 PM
03/30/11 08:32 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Rebuild that 318 and enjoy it. build it for gas mileage, when gas hits $5 a gallon this summer. A good 318 with the right tune should get 18-22 mpg easy. A set of 2.76 gears will help also.
I had a 74 Dart 318 2bbl carb with 2.76 gears and it would roast one tire with ease. Even had the 904 trans and did lots of reverse drops with it. Trany out lasted the car. Car rusted out long before the drive train wore out.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#961223
03/30/11 08:44 PM
03/30/11 08:44 PM
Challenger 1
Cincinnati, Ohio
My parents had a 73 satelite with 318 904 peg leg. That thing would roast tires too. I got in trouble for ruining right rear tires and too many miles on the odemeter when I was supposed to be in school.
Solved both, learned to reach up under the dash and unplug the speedo cable and would put my own tire on when I got the car. That way I wouldn't destroy dad's tires. lol Skipped school many times in that car.
