Vented gas cap? #961195
03/28/11 08:12 PM
03/28/11 08:12 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Anybody have a part # or know if I can get a vented gas cap for my 72 road runner?
Re: Vented gas cap? *DELETED* [Re: RV2] #961196
03/28/11 08:25 PM
03/28/11 08:25 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Post deleted by moparzrule
My
Own
Personal
Adrenaline
Rush
Re: Vented gas cap? [Re: Moparzrule] #961197
03/28/11 08:47 PM
03/28/11 08:47 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Looks like 11632 stant is the vented cap.
My
Own
Personal
Adrenaline
Rush
Re: Vented gas cap? [Re: Moparzrule] #961198
03/28/11 09:47 PM
03/28/11 09:47 PM
IN
ahy Offline
ahy  Offline
IN
If the counter guy will let you walk back and look at the caps there's a good chance you can match a vented one up to your old cap or measurements from the fill tube. I found a new cap for a '47 power wagon at Autozone that way.
Re: Vented gas cap? [Re: RV2] #961199
03/30/11 09:30 AM
03/30/11 09:30 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
A large man in a black suit will hunt you down for letting gas fumes ascape into the air if you use one
LOL
Kevin
Re: Vented gas cap? [Re: C-Tech] #961200
03/30/11 09:42 AM
03/30/11 09:42 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I bought mine at the local parts place. They had two listed and he showed me both and the one that fit I bought.
Re: Vented gas cap? [Re: DANA60] #961201
03/30/11 11:25 AM
03/30/11 11:25 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
The stock spec cap is vented, but has a valve that opens under certain pressure/vacuum in conjunction with the CAS (vapor separator) set-up. If your vapor separator is bypassed/missing/plugged, you may have a vapor lock problem if you go with the stock cap. In this situation, you'll want a cap with an open vent.
As mentioned, the fume police might come after you.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
