what ever happend to the 500 small block? #960903
03/28/11 01:30 PM
03/28/11 01:30 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
thought it was all built....just how bad was it? any times? numbers? what happend??
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: what ever happend to the 500 small block? [Re: toplescuda] #960904
03/28/11 01:40 PM
03/28/11 01:40 PM
organ
maximum entropy Offline
organ
that is an excellent question!
Re: what ever happend to the 500 small block? [Re: maximum entropy] #960905
03/28/11 02:03 PM
03/28/11 02:03 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: what ever happend to the 500 small block? [Re: toplescuda] #960906
03/28/11 06:04 PM
03/28/11 06:04 PM
Someone on here(this forum) insulted and or irritated Ron so he quit posting on here Just like a lot of other racers have
Re: what ever happend to the 500 small block? [Re: Cab_Burge] #960907
03/28/11 06:14 PM
03/28/11 06:14 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The way Ron builds things, it is TOP NOTCH!! Ive spoke with him Via emails about his header building, and about his breather evac system on his engine, and he is GREAT to talk too.
KAsey
Re: what ever happend to the 500 small block? [Re: toplescuda] #960908
03/28/11 07:01 PM
03/28/11 07:01 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
That was finished along time ago. Ron drives it all over the place. Its a hydraulic roller cammed pump gas 501" SB and has 360-1 Indy heads CNC ported by INDY. It runs 10.0s in the heat. It can go faster, but he would get kicked out of the track due to cage requirements. He had a tool steel retainer literally dismantle itself causing the valve to drop. The reason the tool steel retainer failed is a mystery. Its getting back together right now. He has his old trusty crate motor installed in the Valiant for the time being.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: what ever happend to the 500 small block? [Re: PUNK] #960909
03/28/11 07:26 PM
03/28/11 07:26 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ow. thats what nightmares are made of. Did it hurt the block or heads?
Re: what ever happend to the 500 small block? [Re: Hot 340] #960910
03/29/11 07:44 PM
03/29/11 07:44 PM
P
PUNK Offline
PUNK  Offline
P
The block and heads are fine. The valve stayed in the head but got mangled pretty bad. So far there is no signs as to what may have caused this unusual retainer failure. It will be back together shortly. The head and piston now have a little character to them, but for the most part it will be OK. Im still wodering what could have caused this retainer to fail. The engine is using a hydraulic roller lifter that doesnt have very much spring pressure, relatively low max RPM and no coil bind issues. Is it possible that he simply had a bad retainer? These retainers seem to have a good reputation. I guess even the best parts will fail at times. Rons a SUPER smart guy and he will get down to the bottom of this real soon.
Re: what ever happend to the 500 small block? [Re: PUNK] #960911
03/29/11 08:40 PM
03/29/11 08:40 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Ron is Da Man!
He goes first class all the way, I miss him, Here's to ya, my brother!!
You know it's funny, he had a clip of his car pulling it out of the trailer and i said....That sounds EXACTLY like my 517, the same roller chirp, the same throttle response, everything.
Came to find out he's running like the exact same Bullet HR cam in his 501 smallblock as I am in my big block.
Come on back, Ron!! Stay for us good guys, not the d-bags!!
WIZE
In Car:
Re: what ever happend to the 500 small block? [Re: PUNK] #960912
03/29/11 09:36 PM
03/29/11 09:36 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The retainer is going back to Comp for material analysis. It sure looks like brittle metal to me, the way it shattered like a piece of glass. I rarely see retainer failures, & this is first tool steel one I've seen. I've had couple sets of heads come in with moly retainers on roller springs that were broken similarly before, kind of spiderweb of cracks all over them. & saw a Ti retainer with the entire bottom step of it where the locks sit in just break right off on a circle track head that came in a few months ago.
I've used those LW Comp tool steels on alot of high spring press applications (up to about 800 open) including both of my own cars, with no issues. I've got about 9200 miles on the set in my Road Runner on a small solid roller spring (215 seat 550 open) I will continue to use them in future, I think it's an isolated deal. He got real lucky that the valve stayed intact, it's a testament to the quality of a Ferrea Comp Plus valve.
Re: what ever happend to the 500 small block? [Re: RyanJ] #960913
03/30/11 10:04 PM
03/30/11 10:04 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
does anyone have a link to the original build ron had posted a while back??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: what ever happend to the 500 small block? [Re: Stroker Scamp] #960914
03/31/11 08:40 AM
03/31/11 08:40 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
