5.7 hemi #960811
03/28/11 07:47 AM
03/28/11 07:47 AM
norway
aufles.mopar Offline OP
norway
hi
i have bougt a 2006 5.7L hemi to put into my hotrod.
i'll use megasquirt ECU to controll the fuel and MSD to controll the ignition.
on that engine it is 4 solenoids that is mounted on top of the camshaft area.i think it is to shut of 4 of the cylinders to get lower fuel economy.is it anyone who know if i have to put power on them or just leave them without any conection to get it running on all 8 cylinders.
on my 6.1Lhemi those holes is plugged with an plastic plugg.
thanks runar
1971 cuda and 1934 plymouth hotrod
Re: 5.7 hemi [Re: aufles.mopar] #960812
03/28/11 10:15 AM
03/28/11 10:15 AM
houston texas
gremlinsteve Offline
houston texas
u can remove them and addthe same plugs that are on your 6.1 or leave them in place as is.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 5.7 hemi [Re: gremlinsteve] #960813
03/30/11 07:19 AM
03/30/11 07:19 AM
norway
norway
hi
thanks for the answer.i'll use them unwired
thanks runar
