Re: Fast Ratio steering-yes or no?
[Re: DaytonaTurbo]
#960803
03/28/11 04:06 PM
03/28/11 04:06 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
I've heard when you run their fast ratio pitman you are also supposed to run their power steering box as well. Something about them moving the lock points so you can't over-twist the faster ratio pitman...?
This is true. You can run the arms without the modified box but you MAY have trouble. The box is basically a hydraulic ram much like a press or a jack. The ram moves the sector shaft/pitman arm for you. The factory T/A boxes used a modified stop to prevent the suspension from binding. when you turned the wheel all the way the limit was in the box not the linkage. If you do not limit the box it will put excess strain on the linkage when the wheel is turned to it's maximum amount. You are using the linkage to limit the travel and it may bend the linkage or over stress the tierod ends.
If you are not pushing it against the turning limit it would be OK but continually pushing it against the limits and you will eventually give your self problems.
[Re: Kern Dog]
#960804
03/29/11 02:44 AM
03/29/11 02:44 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I have the fast ratio Idler AND pitman in my Charger. TTI says their headers wouldnt clear, but mine do. I have the Stage 3 Firm Feel steering box too. The turns lock to lock went from 3 1/2 down to about 2 5/8 lock to lock when I added the FR arms. PLUS the steering effort went up a little. FANTASTIC upgrade over the usual overboosted Mopar schmere.
Okay Miguel, MORE specs it is: 70 Charger 440/493 with Edelbrock heads. Rebuilt suspension. 18x9 front wheels with 275 40 18 tires.
[Re: migsBIG]
#960806
03/29/11 10:41 AM
03/29/11 10:41 AM
Posts: 295 Circleville, Ohio
Evil67
Circleville, Ohio
I like the fast ratios....harder to turn though....
Former Username - 71Cuda Current Ride: 1967 Dart - 340
[Re: Evil67]
#960808
03/30/11 10:05 AM
03/30/11 10:05 AM
Posts: 21,656 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
I thought fast ratio would make it easier to turn, or are you talking about manual steering while I am refering to a power steering in my car?
[Re: migsBIG]
#960809
03/30/11 02:10 PM
03/30/11 02:10 PM
Kern Dog
Granite Bay CA
Fast ratio means that for each revolution of the steering wheel, the tires move further. The 24 to one manual would be S L O W ratio. Whats that? 5 or 7 turns lock to lock? Most Mopar power steering boxes are 3 1/2 turns so they are much "faster" than the manual boxes but you dont notice the increased effort because of the power assist. Take off the pump belt and try to steer! The longer pitman and idler that ARE the Fast Ratio variety make the tires move faster and further, but once again, the power assist hides some of the increased effort. My Charger feels like a manual 16 to one box. Just right!
