Electronic ignition issues..pulling my hair out.. #960706
03/27/11 11:52 PM
03/27/11 11:52 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Posted this in the wrong area..here is my dilemma:
My 69 Coronet recently burned up the engine wiring harness. I installed a new harness and it runs great. Problem is when starting it, it only fires when I release the key from he START position, to the RUN position. I have tried new switch, just put in new ECU and wiring. Everything seems wired correcty and matches the instructions, but same result. What is wrong here! I have been messing with it for months now, and its the same result no matter what I do. Since its a 69, is there a splice I need to make to get juice to it in the START position? I am lost...
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960707
03/27/11 11:54 PM
03/27/11 11:54 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Not knowing what you did/ changed for wiring, I can't say specifically, but here's how it "used" to work.
Chrysler ignition switches have THREE important, separate circuits inside, that is what amounts to three separate switches SO FAR AS THE ENGINE goes.
1. Ignition run. This is normally the blue wire, which feeds the ballast resistor (originally) the regulator, electric choke if you have it, and the alternator field on 70/ later cars, and may feed the idle stop solenoid, don't remember. In any case it is LIVE in "run."
2 "Engine start." This is the wire that feeds the fender/ firewall mount start relay, and fires up that relay when you twist the key to "start."
3 Ignition resistor/ ballast "bypass" circuit. This wire ALSO comes from the switch, and feeds "hot" battery to the coil + when the key is in "start" and is normally brown.
I would guess that you are missing this last connection. You have a wireing diagram?
Post Extras:
dssaa
super street
Reged: Oct 06 2003
Loc: Colorado Re: Electronic ignition issues..pulling my hair out.. [Re: Yancy Derringer]
#6553435 - Sun Mar 27 2011 10:28 PM Edit Reply Quote Quick Reply
I have a color wiring diagram, and everything seems correct according to that. I am wondering about my starter relay now that you mention that portion...I am going to go look at it and the wiring to/from it. Maybe I have an issue there?
Post Extras:
dssaa
super street
Reged: Oct 06 2003
Loc: Colorado Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa]
#6553477 - Sun Mar 27 2011 10:48 PM Edit Reply Quote Quick Reply
Okay, on the ignition switch itself, all the terminals are marked. There are posts marked "ignition 1" and "ignition 2". I am assuming one of these is start position, the other the run position? Is that true, and if so, which is which..I can trace that wire under the dash and to the resistor. I have checked the new harness over and over, and its wired correctly. Starter works fine, so assuming the relay is still good, all wires look good. Ideas?
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960708
03/28/11 12:12 AM
03/28/11 12:12 AM
You're getting no fire in start (ign2) so trace continuity from the ign2 terminal on the ign sw out to/thru the bulkhead & onward to the downstream side of the ballast. This ign sw terminal has a brown wire on it. When I say start I dont mean the "st' terminal (yellow wire) which is to the starter relay & not a prob here as it is cranking over EDIT I'm assuming 4 pin ECU added w 2 terminal ballast? There's only several connection points/terminals from the ign sw to the coil/ecu which are the only 2 components that need fire, is it wired correct? The coil/ecu/dist pickup and their ign1 blue wire (run) supporting wiring are good as does run when you let off the key
Re: Electronic ignition issues..pulling my hair out.. [Re: RapidRobert] #960709
03/28/11 12:51 AM
03/28/11 12:51 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I put a test light on the Brown Wire terminal for ignition 2 at the bulkhead connector. When the key is in run position, it has juice. When I turn it to start, nothing. Something is wrong here...
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960710
03/28/11 12:58 AM
03/28/11 12:58 AM
The eng half of the bulkhead w the brown wire will b hot in run as current feeds back from the downstream end of the ballast which has the brown wire as current is fed to the other end of the ballast from the blue wire in run so that's normal. While someone holds the key to start check for fire at the ign2 (brown wire male terminal) on the ign sw then continuity on the connector that plugs onto the sw then the brass terminal in the rear half of the bulkhead
Re: Electronic ignition issues..pulling my hair out.. [Re: RapidRobert] #960711
03/28/11 01:21 AM
03/28/11 01:21 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
okay...I will give that a shot tomorrow...thanks for the help..will update tomorrow evening.
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960712
03/28/11 05:28 PM
03/28/11 05:28 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
That's it. check at the bulkhead and if not there, at the ignition switch.
Re: Electronic ignition issues..pulling my hair out.. [Re: Yancy Derringer] #960713
03/29/11 01:04 AM
03/29/11 01:04 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So, I have juice in the run position at the ignition switch..now what...???
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960714
03/29/11 01:14 AM
03/29/11 01:14 AM
You have juice at the run (ign1) circuit. (in addition) need juice at the brown wire (ign 2) ign sw terminal out to the bulkhead w key turned to crank. Can pull the yellow wire off of the fender starter relay to disable the starter till you get it sorted out
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960715
03/29/11 01:41 AM
03/29/11 01:41 AM
Indiana
P
Pentastar440 Offline
P
Indiana
You are probably running a 4 wire connector with a single ballast resister, with your new electronic ignition system. Run a splice from the brown wire and the blue wire and it will run.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Electronic ignition issues..pulling my hair out.. [Re: Pentastar440] #960716
03/29/11 02:09 AM
03/29/11 02:09 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
This may sound off the wall but ---how is it grounded. My Control unit is grounded with external star washers got to get to bare metal under it bolted to the inner fender well.
If your grounding is poor you will have nothing but problems.
Maynard
Re: Electronic ignition issues..pulling my hair out.. [Re: Pentastar440] #960717
03/31/11 12:08 AM
03/31/11 12:08 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So...I have juice at IGN2 when the key is turned..but nothing out of the bulkhead. In IGN1/run, juice at bulkhead. I have the brown wire and blue wire mated to the same terminal at the ballast resister. Yep, single resistor 4 wire setup. What splice would I use, or do I pull bulkhead connector and check connections there.. Car runs fine and starts fine when key is released..but its just wrong and I want it right..
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960718
03/31/11 12:23 AM
03/31/11 12:23 AM
You have fire at the ign2 (brown wire) ign sw terminal in "start" right? and the connector on the back of the ign sw is good (continuity) right? OK, seperate the bulkhead & check for fire at the brown wire brass terminal on the firewall half of the bulkhead in "start" (use a NAPA 725147 male terminal to clean it). W it clean then check/clean the male terminal in the front bulkhead half if needed w a mini steel bristle brush.
Re: Electronic ignition issues..pulling my hair out.. [Re: RapidRobert] #960719
03/31/11 12:38 AM
03/31/11 12:38 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Hey Robert..yeah, I pulled the terminals off the bulkhead connector, and there is definitely evidence of some burning..and thats not surprising considering what happened. Gonna go clean it up right now and see what gives.
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960720
03/31/11 12:46 AM
03/31/11 12:46 AM
Montana
Y
Y
Montana
If this is true you have it WIRED INCORRECTLY
Dark blue goes to one side of ignition resistor
Brown and coil + go to OTHER side of ignition resistor
Dark blue is hot in RUN
Brown is hot in START
THE DIAGRAM BELOW HAS ONE MISTAKE. DO NOT USE the yellow wire as shown, use the BROWN wire in place of YELLOW
Re: Electronic ignition issues..pulling my hair out.. [Re: Yancy Derringer] #960721
03/31/11 01:05 AM
03/31/11 01:05 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Robert/Yancy.. Thanks for all your help. I pulled the connectors at the bulkhead and was cleaning all the terminals. Rewired the ballast and ECU back to how they are supposed to be. I picked up end of new harness and looked, and the terminals for the brown wire and one next to it were bent so they would not make correct contact at bulkhead. I straighened them out, replugged it all in, and its working perfect now. Man, do I feel dumb. I owe you both a beer. Actually, over the past year, I probably owe Robert a case! Why are Mopars so frustrating..and so much fun at the same time. Do you guys come down to the big Mopar show here at Bandimere Speedway in May? If you do, first round is on me...
Thanks again
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960722
03/31/11 01:23 AM
03/31/11 01:23 AM
Mopars (w time) will teach a person how to handle frustration by not allowing it to happen . I had a massive vac leak on a 318 after a swap to a streetmaster intake & after ch intake gaskets (3) times yes 3 times it turned out to b several of the brass inserts in the 4 corner bolt holes in the thick Felpro base gasket were higher (taller) than the gasket itself & there it was . I hear that event is well worth attending. Glad ya got it Dave
Re: Electronic ignition issues..pulling my hair out.. [Re: RapidRobert] #960723
03/31/11 01:47 AM
03/31/11 01:47 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
It is well worth attending. The swap meet is usually not very good, but he racing in great, the people are great, and the beer is cold. Great people. My wife and I go every year..usually drive our 73 Challenger there..I think we will take the 69 Coronet this year. Any events up your way..say mid July..we are heading that way...
Re: Electronic ignition issues..pulling my hair out.. [Re: dssaa] #960724
03/31/11 01:54 AM
03/31/11 01:54 AM
Not sure what's going on yet
Re: Electronic ignition issues..pulling my hair out.. [Re: Yancy Derringer] #960725
03/31/11 11:13 AM
03/31/11 11:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I can't see the diagram you are posting but I can guess... the Mopar Performance one with orange box and a yellow wire arriving to ballast coil splice.
THAT DIAGRAM is just correct for mids/lates 70s cars when the coil source on start moment was changed from ign switch to starter relay. These Starter relays use double prong on start hook up one to feed relay and the other one to feed ballast/coil on same moment, and saves one wire coming from ign switch, and one cavity from bulkhead
