Rally Guage Bezel removal #96023
07/28/08 12:00 PM
07/28/08 12:00 PM
White Plains NY
VitaminCRunner Offline OP
White Plains NY
Was thinking of buying new bezels for my 70 Runner.
Is this an easy process, I see screws in the front are there any tips or tricks?
Re: Rally Guage Bezel removal [Re: VitaminCRunner] #96024
07/28/08 02:31 PM
07/28/08 02:31 PM
Mass
Mike Mancini Offline
Mass
You will need to drop the steering column down and remove the entire gauge cluster. The bezel screws to the cluster housing from behind.
-Mike
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: Rally Guage Bezel removal [Re: VitaminCRunner] #96025
07/28/08 07:00 PM
07/28/08 07:00 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Very strait forward..
But as mentioned drop the column down, pull the front screws, disconnect the nylon speedo connector. Pull out the entire bezel slowly.
I actually found that by pulling out the radio & plate allowed my hand to get up behind the speedo more easily.
Also tag each harness plug.
Just my ..
