Lifter question #960158
03/27/11 06:02 PM
03/27/11 06:02 PM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
I just installed a new Lunati cam and lifters in my 440, all the lifters except for one I can push in slightly with the push rod. One is hard like a solid lifter.
So before I prime and fire this engine up, should I worry about it, or get a replacement?
Re: Lifter question [Re: T2R9] #960159
03/27/11 07:34 PM
03/27/11 07:34 PM
Do you have a priming tool? If so how about adjustable rocker with the proper length pushrods? If yes to both prime the motor first while turning the motor over with no pusrods and then check the lifters If no to both questions put them in the motor, make sure they rotate freely in the lifter bores and go for it Do not let the motor idle at start up, make the motor run at or above 1500 RPM for 20 to 30 minutes to break the new cam and lifters in Also make sure the motor starts up immediately , no prolong grinding on the starter
