1970 Cuda Moisture Barrier #959547
03/26/11 11:26 PM
03/26/11 11:26 PM
Long Island, NY
70plymA34 Offline OP
Long Island, NY
Does anyone have pics of properly installed moisture barriers that go on the door prior to mounting the door panel. Also pics of how the string caulk is applied for the barriers in back seat as well. Any info would be great. I remember there being a paper tape applied somewhere on the barrier as well.
Re: 1970 Cuda Moisture Barrier [Re: 70plymA34] #959548
03/28/11 09:34 PM
03/28/11 09:34 PM
WNY
slimert Offline
slimert  Offline
WNY
My 70 Cuda was unmolested. Could only find one picture of the pass. side door. The plastic looks like it was attached with a spray adhesive. The rear plastic was attached with strips of white rope caulk. Can't find any pictures though.
Re: 1970 Cuda Moisture Barrier [Re: 70plymA34] #959549
03/28/11 11:28 PM
03/28/11 11:28 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
This is on a 73. This is the rear. You can see the rope caulk that held the plastic on. The upper right side fell down but you can see where it went.
Craig
Re: 1970 Cuda Moisture Barrier [Re: denfireguy] #959550
03/29/11 12:56 PM
03/29/11 12:56 PM
Long Island, NY
Long Island, NY
thank you very much. they were still in the car during disassembly but i did not take detailed shots of. just want to make sure it goes back in properly. if not done right i believe it can warp the vinyl door panel over time.
Re: 1970 Cuda Moisture Barrier [Re: 70plymA34] #959551
03/29/11 03:30 PM
03/29/11 03:30 PM
SC
Cooda Offline
Cooda  Offline
SC
Here is a picture I took of a virgin 1970 Cuda...
