Need to move rearend back got??? #959480
03/26/11 09:16 PM
03/26/11 09:16 PM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
Does anybody make a spacer block kit to do this. I need more clearance on the front of the wheel well. This is on a b-body 70 charger.
Re: Need to move rearend back got??? [Re: 440charger500] #959481
03/26/11 09:53 PM
03/26/11 09:53 PM
ill
dennismopar73 Offline
ill
i have made my own out of 1/2 aluminum never a prob
Re: Need to move rearend back got??? [Re: 440charger500] #959482
03/26/11 10:12 PM
03/26/11 10:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't recall if it's Dodge or Plymouth but the front spring hangers on one of the B bodies is 3/4" longer than the other....
Re: Need to move rearend back got??? [Re: 1_WILD_RT] #959483
03/26/11 10:51 PM
03/26/11 10:51 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What about drilling another hole in the spring pad on the axle housing?
Re: Need to move rearend back got??? [Re: Kern Dog] #959484
03/26/11 10:54 PM
03/26/11 10:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No. You want the hole directly over the axle center line. Shim the mount or replace the front mount as said above is the proper way.
Re: Need to move rearend back got??? [Re: 440charger500] #959485
03/26/11 10:58 PM
03/26/11 10:58 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Somebody had this up on unlawful last week,
somebody on that post stated they sold them,
soory cant be more help
Re: Need to move rearend back got??? [Re: B1KILLER] #959486
03/27/11 03:39 PM
03/27/11 03:39 PM
Redding,CA USA
Redding,CA USA
Ok I will read through the unlawful forum and try to find it. Thanks
Re: Need to move rearend back got??? [Re: 440charger500] #959487
03/27/11 09:40 PM
03/27/11 09:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
AndyF(AR Engineering) I believe makes spacers for front spring hangers but just remember whatever you do up front effects the rear hangers
Gus
64 Plymouth Savoy
Dana 60
