Re: Indy quality control
[Re: Mopar-Al]
#959201
03/26/11 06:01 PM
03/26/11 06:01 PM
Hope you bought it from a dealer and not Indy direct. If you bought it from Indy direct, YOU ARE SCREWED!
#959202
03/26/11 06:03 PM
03/26/11 06:03 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
not sure why it does not fit but I am sure INDY will say it's your fault
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#959203
03/26/11 06:09 PM
03/26/11 06:09 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Ha ha ha yer right. I did open the box. I think it came from Mancini. Im doing a project for a friend. He may want to ship it back
[Re: B G Racing]
#959205
03/26/11 06:26 PM
03/26/11 06:26 PM
Mopar-Al
Alabama
We have seen a lot of issues with fit,most often it is the deck height of the engine that create the problem.As far as port alignment we see it on various manifolds.Gasket and port matching is almost a must.
Yes, I agree with your comment. The issue I see is that 2 intake runners 1 and 3 and the 2 bolt holes them selves won't match either. Like the whole runner section itself is shifted. It also sets flat and square with all aligned in the back of the intake. The other 2 intakes I used have zero issues. I am familiar with the decking, port matching, and intake face cutting. This intake looks like it was made longer on the bottom , past the bottom of the intake openings. This is causeing the intake not to set flush on the heads.
[Re: Mopar-Al]
#959206
03/26/11 06:29 PM
03/26/11 06:29 PM
Send it back. Especially if your other ones fit the correct way.
[Re: Stanton]
#959211
03/26/11 09:52 PM
03/26/11 09:52 PM
How about a set of 572-13 heads and the spark plug holes not machined deep enough. How about a 1/2" too shallow.
