Narrowing DANA 60 questions for my Challenger #959175
03/26/11 05:20 PM
03/26/11 05:20 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I have an old 1 ton Dodge pick up rear axle. I disassembled it & cut off the old full floater ends. I made up my own rear axle narrowing fixture out of some steel discs I made up for where the center section bolted & made up some steel housings end flanges the slip into & bolt to the after market Strange housing ends. All four discs have a 1-1/2" bore that I slide a 1-1/2 solid bar thru the axle from one end to the other to hold all suare & true.
The car is mini tubbed & I have Caltracs w/ Split mono leafs w/ a Doctor Diff 1" relocation kit. The wheels I have are 15" x 12" Welds with 315/65/15 Drag Radials. Just mocking the wheels in the wheel tubs everything fits nicely. Its tight but it fits. Mocking it up with a wheel flange to wheel flange I have a dimension of 54".
My questions are. How do you back figure the o.a.l. length to cut down the axle housing? Then adding the width of the axle flanges.I plan on running Strange axles & rear brake. Then I will need to add the length of all of this.
So what's the best way to get it all correct the first time?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Narrowing DANA 60 questions for my Challenger [Re: 6PKRTSE] #959176
03/26/11 07:00 PM
03/26/11 07:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The axle flange standout is 2.5" from the housing flange so subtract 5" from the overall axle flange-to-flange width to get the housing width. Add the drum or disc thickness to each side for a precise overall width dimension.
